Yanmar 1820D front driveline and sheild
   / Yanmar 1820D front driveline and sheild #1
Callan
Tucson
Yanmar 1820D
Need help I bought tractor without front driveline and can’t find a replacement any help appreciated anyone make their own
   / Yanmar 1820D front driveline and sheild #3
I assume by driveline you meant driveshaft?
   / Yanmar 1820D front driveline and sheild #4
The shield and hardware are listed separate in the parts view illustration but I think hoye can fix you up with what you need.
Tried Hoye they referred me to this forum
Hoye responded
   / Yanmar 1820D front driveline and sheild #7
Hmm were you requesting a used driveshaft? Perhaps I was mistaken but I looked your shaft up on their website. Maybe the shield is no longer available? What happened to the original driveshaft?
Bought tractor from a guy who bought it from a guy and only used 2wd
   / Yanmar 1820D front driveline and sheild #9
Hoye shows a driveshaft with ujoint end but no splined end for around 200. You could measure the distance from transfer case to differential & if the length is shorter, buy the hoye shaft, take it to a machine shop with the tractor & have them cut and spline/yoke it for you depending on the connection needed. You'll still need shield & ujoint/ fasteners/seals, but the drive shaft should be done. Would need to make sure the xfer case isn't trash ... why would someone pull the shaft from a working xfer case even if they don't use 4wd?
I blew a rearend in eastern Wyoming/western Nebraska once on a datsun 4x4, pulled the shaft and limped into Cheyenne on front wheel only, but kept the original driveshaft to mate up to a boneyard rear end.
   / Yanmar 1820D front driveline and sheild #10
If that doesn't work, a driveline shop should be able to custom fab one for you. Might not be oem, but it would work.
2007 CATERPILLAR D5GXL CRAWLER DOZER (A51406)
2007 CATERPILLAR...
2015 Ford F-150 Pickup Truck, VIN # 1FTEW1EFXFFA41510 (A51572)
2015 Ford F-150...
John Deere 5090E Tractor with Loader Prep Package, 2 Rear Remotes, Warranty Until 2028 (A53472)
John Deere 5090E...
2015 INTERNATIONAL 28 PASSENGER HANDICAP ACCESSIBLE SHUTTLE BUS (A52577)
2015 INTERNATIONAL...
2002 WESTERN STAR 4900 EX TANDEM AXLE SLEEPER TRUCK (A52577)
2002 WESTERN STAR...
2006 CATERPILLAR 345CL EXCAVATOR (A51246)
2006 CATERPILLAR...
