Yanmar 1820D front driveline and sheild
   / Yanmar 1820D front driveline and sheild #1
Callan
Tucson
Yanmar 1820D
Need help I bought tractor without front driveline and can’t find a replacement any help appreciated anyone make their own
   / Yanmar 1820D front driveline and sheild #3
I assume by driveline you meant driveshaft?
   / Yanmar 1820D front driveline and sheild #4
The shield and hardware are listed separate in the parts view illustration but I think hoye can fix you up with what you need.
Tried Hoye they referred me to this forum
Hoye responded
   / Yanmar 1820D front driveline and sheild #7
Hmm were you requesting a used driveshaft? Perhaps I was mistaken but I looked your shaft up on their website. Maybe the shield is no longer available? What happened to the original driveshaft?
Bought tractor from a guy who bought it from a guy and only used 2wd
   / Yanmar 1820D front driveline and sheild #9
Hoye shows a driveshaft with ujoint end but no splined end for around 200. You could measure the distance from transfer case to differential & if the length is shorter, buy the hoye shaft, take it to a machine shop with the tractor & have them cut and spline/yoke it for you depending on the connection needed. You'll still need shield & ujoint/ fasteners/seals, but the drive shaft should be done. Would need to make sure the xfer case isn't trash ... why would someone pull the shaft from a working xfer case even if they don't use 4wd?
I blew a rearend in eastern Wyoming/western Nebraska once on a datsun 4x4, pulled the shaft and limped into Cheyenne on front wheel only, but kept the original driveshaft to mate up to a boneyard rear end.
   / Yanmar 1820D front driveline and sheild #10
If that doesn't work, a driveline shop should be able to custom fab one for you. Might not be oem, but it would work.
Miller Trailblazer 250G 4,000 Watt Welder/Generator Set (A51691)
Miller Trailblazer...
2011 Ford F-150 4X4 Pickup Truck, VIN # 1FTFX1ETXBFC66737 (A51572)
2011 Ford F-150...
UNUSED RAYTREE RMSG-29 29" STUMP GRINDER (A51248)
UNUSED RAYTREE...
24'' Mini Excavator Bucket (A51573)
24'' Mini...
2016 Sure-Trac 20 Ton Pintle Trailer, VIN # 5JW2U2522G1121114 (A51572)
2016 Sure-Trac 20...
2004 Ford Taurus SE Sedan (A51694)
2004 Ford Taurus...
