yanmar 18 6d starter
/ yanmar 18 6d starter #1
cinder
yanmar 187d
does anybody know the starter no. of a yanmar 186d tractor and where to get one?
/ yanmar 18 6d starter #3
I bought one from my local Auto Electrician a few months ago. Trouble is I'm in Australia. Before I bought I did some research on the web and on Ebay. Trouble was, everything was in the US. Have a look, they're out there. Hoye Tractor is a good place to start, even if they haven't got it they might know what will fit.
/ yanmar 18 6d starter #4
Here you go. Try Yanmar part # 121450-77010 which is a Hitachi starter # S114-235A.
Here's a Google search. I see some of the vendors show it as 9-tooth, others 11-tooth, so I would do some extensive research to sort out flaky cross-references that go to almost-fit frustration makers.
I have no idea if the same starter was used for all years of YM186, or on other Yanmars. It might also appear on Yanmar Marine diesels but those vendors prices are high.
You might get lucky and discover that this Hitachi starter was also used by Nissan or somebody, which would mean there are cheap rebuilts at Autozone. Also an auto electric shop might look at it and recognize it takes a universal Hitachi overhaul parts kit, for an inexpensive overhaul ... if you're real lucky.
Thanks for the info, i just found a guy that might be able to fix the starter if not have to buy a new one. But another question i have a 187d theres a lever under the steering wheel there is a l shaped 1/4" rod it runs to the valve cover pan on top of the motor. Theres a return spring on it and you pull it. Theres like 3 hinges on it? Also does any body know how to turn on the glow plug? Last for the moment its a 3 speed power shift with a lever on the dash and on the right side by the seat theres a another lever with a tag on the fender that says 1-n-2-3 what is it for?:confused:
/ yanmar 18 6d starter #6
The 1/4" rod is your compression release. Pull that prior to turning the key to crank position. This holds open your valves allowing the engine to turn over freely. Hold it in that position while allowing the engine to turn over for a few seconds or until your oil light goes off. No more than 10 seconds per manual. When oil light goes off, push lever in and bang, she ought to be going. Saves wear and tear on starter and easier on bearings. The thermal start is activated by turning your key counter clockwise and holding, my manual says until light goes off, my light doesn't go off, so I hold it 10 seconds or so. Truth is, here in East Texas There are few times I even need this feature. You should see a little bottle reservoir located to the left of the rocker arm cover. A small hose goes from it down to a small electric heater/valve located on your intake manifold. That is your thermal start. I think the lever on the fender you reference is your pto speeds. #1 would be your standard 540rpm.
Well i guess i do have another question. there is a plug on the left rear side between the seat and tire like a heater plug i think it goes into the transmission is this a heater plug? How are these tractors anything any body can tell me about these? Thank guys:)
Also i have a 187d does any body know when these were made or how i can tell by my no.?:) thanks guys
/ yanmar 18 6d starter #9
some will tell you a year they were made but from what i have read on here its impossible from what folks on here know to tell what year a tractor was built based on serial #s. Reason is that model year in japan back then was not as important as it is here, and no notes that those that know of were ever made.
How come you have all these tractors but know little about them, did you inherite them or just took a notion to buy them??
Winston i have a manual, i think maybe the IT shop manual or either that terrible potocopied thing they give you with a VN recon but i remember reading "DO NOT" hold thermostart for more than 10 seconds. So you are right on, and i also dont think it will cut off unless it breaks.
/ yanmar 18 6d starter #10
As for year model: Here is a dealer brochure showing Copyright 1986. That corresponds to what I have read on here, so far as I recall. Maybe someone else has better information.
What I remember reading here is: YM1510 (Japan) and its US twin YM186 were first sold in 1979-1980. The early ones had the shifter on the transmission tunnel. About 1983, on YM186, the shifter was moved to the dashboard. I don't know if YM1510 also had this upgrade or if they just dropped the model over there. Then in 1986 a major upgrade lengthened the wheelbase out to something more reasonable, both for a larger belly mower and so you could get off the tractor without needing a cheerleader kick to get your leg over the steering wheel. (There isn't enough room on the floorboard to rotate your left foot around to dismount like a bicycle or horse). They called this improved model YM187. It probably had some other improvements than just length.
And I think YM187 was sold clear through the end of the period when Yanmar sold in the US, about 1981??? To guess at the year of manufacture, estimate (roughly!) 10,000 tractors per year starting from 1986 and compare your serial number to that. I don't think there is any closer way to estimate it. Incidentally parts are ordered by serial number, not by year.
Does somebody have better information?
The reason i don't know much about it is i just bought it last weekend they handed me the starter i know buying something and not hearing it run. I guess i'm going on hope and a prayer. Bought it from a farmer most at least tell the truth. I know i use to farm and most i knew was trust worthy. But i'm pretty handy on working on things so i hope to get it going. You could see on the side of the starter where they have been tapping on it. So something i've learned in my older age is it's easier to ask Questions and find out all you can about something then to fix the mistakes you make by not asking any questions. And i like tinkering with stuff like that. So i want to thank all you guys for the information.:thumbsup:
At first i thought that what it was but since then i found a small flat spot on the left side of the tranny i had to burn the paint and there it was 187d- serial no.. I'm not sure theres much differance between the 186 and the 187?But enough about me all i want to know is something about this tractor?
/ yanmar 18 6d starter #14
oh ok. I seem to be the only one who picked up on that, not trying to be an a$$hole though.
Ok guys i've had t his a couple of months now i know a bit more about these things now. The starter, if your going to keep the tractor go to hoye and buy a good starter. the hitichi starters might be cheap but thats exactly what they are CHEAP. I bought my tractor non running so i needed a starter to get it going, burnt the cheap starter up trying to get it going. It was a 9 tooth but but the tractor had a 11 tooth but the hitichi book said it would work , i had to shave the nose of it because it would hit the flywheel and lock the motor up. Ended up buying hoye starter. It has more torque and does not get hot like the cheap starter. The cheap starter gets hot very quick. But after replaceing the injector pump, the front pto or ( shaft front drive)had to split the tractor for the 4 wheel drive and a few other things i have it purring. Looks like it will be a nice tractor.:thumbsup: moral to the story be carefull of the cheap starters! Also i tried to have the old one rebuilt by a shop but it was dead they could not fix it.
/ yanmar 18 6d starter #17
If by "Hitichi" starter, you mean "Hitachi", that is the Yanmar OEM installed starter.
Oem or not it's about half the starter hoye sells. Call and ask them they will tell you. I learned the $$ way.
/ yanmar 18 6d starter #19
I doubt we are talking about a genuine Japanese Hitachi. Let's hope theirs will also last 30 years.
SET OF PALADIN JRB 60" PALLET FORKS (A52707)
SET OF PALADIN JRB...
New/Unused 2in Ratchet Strap (A61166)
New/Unused 2in...
2006 HONDA RANCHER ATV (A62130)
2006 HONDA RANCHER...
UNKNOWN 500BBL WHEELED FRAC TANK (A58214)
UNKNOWN 500BBL...
PENDING SELLER CONFIRMATIONS (A59909)
PENDING SELLER...
2010 MULTIQUIP 25KW GENERATOR (A58214)
2010 MULTIQUIP...
