3-Point Hitch yanmar 1500
/ yanmar 1500 #1
speedy2
yanmar ym1500
It has been a week since I changed the motor oil and filter, drained transmission, removed hydraulic filter and cleaned and replaced it,filled trans with new fluid, changed fuel filter. I asked if there was a way to purge the air from the system and told to move the 3 pt up and down to remove any air in system. I tilled about a1/3 acre with no problem. Yesterday will till a small spot in garden the 3 pt started squealing when beening raised. What could be the cause of this? Speedy2
/ yanmar 1500 #2
The squeal is probably the overpressure bypass.
It can squeal when the 3-point is raised too high. Adjust the feedback rod so it pushes and resists your attempt to lift the last few inches.
Or if you hear the overpressure bypass squeal before the implement is lifted very far, then possibly the implement is too heavy, or the shutoff valve under the seat is near closed.
I doubt this is a trapped-air issue.
7x16 Enclosed Spray Foam Trailer (A65563)
7x16 Enclosed...
2022 FORD TRANSIT 250 CARGO VAN (A59905)
2022 FORD TRANSIT...
HD Bale Ring w/ Hay Saver (A66408)
HD Bale Ring w/...
2010 FREIGHTLINER M2 BUCKET TRUCK (A65643)
2010 FREIGHTLINER...
2006 Dodge Ram 1500 Pickup Truck (A61568)
2006 Dodge Ram...
John Deere Pallet Forks (A66285)
John Deere Pallet...
