OP
rswyan
Super Star Member
- Joined
- May 12, 2004
- Messages
- 13,184
- Location
- Northeast Ohio
- Tractor
- Kubota B2910, Cub Cadet Pro Z 154S, Simplicity 18 CFC, Cub Cadet 782
Got the feed roller lift/pivot converted over to foot-operated.
Cut two 10" pieces of (I think) 1" Schedule 80 pipe and welded them to the ends of the feed roller pivot arms @ a 45 degree angle. Then took the handle that I cut off of the forward portion of the feed roller pivot arms and used the O/A torch to heat it and bend it (in 4 places) to fit into the pipe I had welded on.
Also cut the rear portion of the feed chute apart and the modified the mounting tabs so that the rear side panels would be parallel to those on the front portion of the chute. This will require adding some additional metal to the bottom panel to accommodate the increased width:
Hopefully this last mod will allow the chipper to pull material in a little easier.
