rswyan
Super Star Member
- Joined
- May 12, 2004
- Messages
- 13,425
- Location
- Northeast Ohio
- Tractor
- Kubota B2910, Cub Cadet Pro Z 154S, Simplicity 18 CFC, Cub Cadet 782
I bought one of these a number of years ago ... didn't really do anything as far as setting it up beyond the basic assembly of the unit. It performed relatively well initially ... aside from the normal stuff like the wobble-joint on the feed roller drive shaft and the feed roller drive belt self-destructing ...
I fixed the wobble-joint by welding on 1/2 impact universal joint I picked up at Harbor Freight and replaced the drive belt with something of decent quality from NAPA.
After that the performance of the unit decreased over a fairly short period of time to the point where the unit achieved the dubious status of "something that I have to fight in order to use" ...
At that point it got parked ... as interest in using it was no longer very high. If I had to guess the unit probably doesn't have more than 30 or 40 hours of use on it at most.
So here's the list of mod's I plan on doing to make this thing a useful tool ... rather than something I have to fight with when I'm using it:
1. Replace all he Chicom grease fittings. I did this yesterday so that's a done.
2. (Further) modify the top link attachment point so that I don't have to remove the pin to hook it up.
3. Modify the discharge chute so that it's 2' higher ... so that I can easily shoot the chips into our Country Mfg. dump cart. (Bonus: no more inadvertently smacking my head into the discharge shoot)
4. Modify the discharge chute so that it rotates at least 180 degrees.
5. Modify the feed roller so that it is more aggressive and grips the wood being fed more securely. This one will like have two stages: 1. an initial quick modification to test out a theory, and 2. an optional rework of the feed roller if I'm not satisfied with the performance of no. 1
6. Relocate the bar that raises the feed roller to the rear of the unit and make it foot operated.
7. Modify the rear portion of the feed chute so that it tapers/flares outward at least as much as the front portion ... which will hopefully facilitate the unit being more inclined to pull stuff in.
8. Add some storage capacity ... mostly for premix and bar oil for the chainsaw, perhaps a scabbard for the chainsaw as well. I have a bottom drawer steel wire basket scavenged from an old freezer that should work nicely for the former.
9. Sharpen the knives using the planer knife jig on my Delta Sharpening Center. This will be a "wet grind" and the knives should be near razor sharp when finished (which could make installing back into the chipper interesting ...
10. Adjust the knife/anvil clearance.
11. Add a pair of 48" long PT 4" x 6" to the base of the unit to raise it up, and bring the drive shaft more in line with the PTO on the Kubota.
