YA3PHBP: Yet another 3PH Boom Pole
/ YA3PHBP: Yet another 3PH Boom Pole #1
rswyan
Super Star Member
Top Poster Of Month
Northeast Ohio
Kubota B2910, Cub Cadet Pro Z 154S, Simplicity 18 CFC, Cub Cadet 782
Since I'm building a root rake/grapple I figured it might be handy to have something to move the upper and lower sections around as it's being built.
Comments/feedback on the construction and design are welcomed and appreciated.
Made this mostly out of drops from the 3" x 2" x 1/4" wall tube that was left over from the grapple. The "T" section for the 3PH is made out of 3 1/2" x 1/4" wall square tube I bought a long time ago for something I don't even remember any more.
The ends of the "T" are plated with some 3/8" angle a friend and I scavenged from a fab shop's drop/scrap dumpster.
Another pic:
The lifting point holes are 1" drilled into 3" x 1/2" thick plate ... and the places they are welded onto are plated with 2" (wide) x 1/4" thick flat stock.
The cast lifting eye is one I picked up from McMaster-Carr for another project ... but couldn't use because the threads were too short. It's 5/8" and is rated for 4800 lbs in a vertical lift.
Still have a couple of things left to do before it can be squirted:
1. Weld on the tabs on the "T" for attaching it to the top link of the 3PH (in this case a Speeco Quick Hitch)
2. Weld on the top reinforcement rod ... which I have to pick up at my steel supplier today. It will be 5/8" hot-rolled solid round stock.
/ YA3PHBP: Yet another 3PH Boom Pole #5
Looks gooder-un! :thumbsup:
Auger Mini Skid Steer Attachment (A59228)
Auger Mini Skid...
FERGUSON 2 ROW CULTIVATOR (A60430)
FERGUSON 2 ROW...
UNUSED 31" HYD TILT MINI EXCAVATOR BUCKET (A60432)
UNUSED 31" HYD...
2018 CATERPILLAR 320GC EXCAVATOR (A60429)
2018 CATERPILLAR...
2017 Freightliner M2 106 AWD Terex Hi-Ranger 5TC55 55ft. Insulated Material Handling Bucket Truck (A60460)
2017 Freightliner...
2018 International WorkStar 7400 Lely 4,500 Gallon T/A Septic Wet Vacuum Truck (A59230)
2018 International...
