XUV / HPX excluded from Trail System?
   / XUV / HPX excluded from Trail System? #11
RollTideRam said:
I thought surely you were wrong, but I looked up the rules and you were not.
TRAIL RULES
I guess they have not taken a look at the trail gator or xuv. Every other utv is on the approved list. Email them again and ask to get the Deeres allowed and send them the specs off the Deere website. I can't see why it would get approval. JC
I would do that and also contact Deere corp and tell them the situation. I know Deere corp will not be happy to know their machines are being singled out.
   / XUV / HPX excluded from Trail System? #12
it's not the deere corporations fault and it's not the parks fault it's just there are some crossings that are not wide enough from what i have been told and the hpx/xuv wn't make it through and it would cost money to adapt these crossing to fit .thats why you need to write the letters and have the money sent or donate money or time to help widen the crossings?? but if the goverment can spend it on lots of other things they can spend it on widening out a few trails.
   / XUV / HPX excluded from Trail System? #13
Tommy:
The XUV is the same width as the rtv, and the rtv is allowed.
   / XUV / HPX excluded from Trail System? #14
It's pretty obvious why they're not allowed, rule #1 explaines it very well, if they broke down or got lost, they'd never be found.
1. Side by side utility vehicles shall only be operated on green trails only.
   / XUV / HPX excluded from Trail System? #15
Nail, head. :)
On a serious note, it is probably due to nothing more than someone not knowing the UTV market players.
On a sarcastic note, it is probably all to due with rubber belts and fluid dynamics.
-Mike Z.
   / XUV / HPX excluded from Trail System? #16
Morning Tommy, as Skip pointed out, the RTV is actually a half inch wider then the XUV but is allowed. It also is heavier so if bridges are the concern the RTV should not be allowed either but since it is and no one involved with this trail has given a reasonable reason why then contact Deere and let them use their resources to open the trail for XUV and HPX owners.
   / XUV / HPX excluded from Trail System? #17
The Ranger is allowed too, and there is no real size difference between a Ranger and an XUV.
   / XUV / HPX excluded from Trail System? #18
It was not long ago I looked at the rules about side by sides and I saw the Mule was allowed, but not the RTV. Perhaps it is a work in progress and you just need enough people to question the rule.
   / XUV / HPX excluded from Trail System? #19
Hmm...the Mule has a bench seat. Does that mean it's a single seater for those of us who are broad in the "beam"?:rolleyes: :D
   / XUV / HPX excluded from Trail System? #20
If you read thru all the rules for the side by sides the seating allotment is determined by how many seat belts are available. If the bench seat has three seat belts then you can have three people.
I was bored since I don't have anything to do anymore so I read thru most of the rules. It gets kind of fuzzy if you have kids riding with you as they need to be in seats with belts and have to be able to reach factory grab rails/handles while in their seat.
2011 NORAM POWER SYSTEMS 100KW GENERATOR (A58214)
2011 NORAM POWER...
IRTPL 10,000 LBS TWO POST LIFT (A58214)
IRTPL 10,000 LBS...
UNUSED FUTURE 40" HYD TILTING BUCKET (A52706)
UNUSED FUTURE 40"...
2019 Land Rover Range Rover Sport AWD SUV (A55853)
2019 Land Rover...
Agri-X 5' 3pt Mower (A53317)
Agri-X 5' 3pt...
2018 Chevrolet Tahoe SUV (A59231)
2018 Chevrolet...
