XT1
Check all your safety switches. I'm always forgetting about these. The seat has one, the brake has one and the blade driver belt handle has one. Make sure you have all of them set up for a normal start.
If you haven't charged your battery, do so or take it and have it load tested. With the key on, the anti-backfire solenoid below the carb should have drained the battery pretty low if it was working. If you were to set the park brake and cycle the key switch from off to on you should be able to hear / feel the solenoid activate and click. Or maybe the PTO is engaged is all.
2019 Ford F-350 4x4 Crew Cab Pickup Truck (A64556)
2019 Ford F-350...
2023 GERINGHOFF PATRIOT RD8R30" CHOPPING CORN HEAD (A64278)
2023 GERINGHOFF...
2016 JOHN DEER 1600 TURBO SERIES II (A66091)
2016 JOHN DEER...
2019 HYUNDAI V12530152-AJS 53' X 102" T/A VAN TRAILER (A59910)
2019 HYUNDAI...
2026 MACK GRANITE GR64F DUMP TRUCK (A63276)
2026 MACK GRANITE...
2019 KENWORTH T880 DUMP TRUCK (A65054)
2019 KENWORTH T880...
