XR4046HC update
/ XR4046HC update #1
AaronS
Platinum Member
Santa Claus, Indiana
LS XR4046HC, New Holland Boomer 1020
I had the tractor at the dealer last week to look into a couple of leaks while it's under warranty and to do the 50 hr services. The A/C was also kicking off after 20 to 30 minutes of running and I wanted to have that looked at.
I had a small hydro oil leak from the rear housing. The dealer found that when it was assembled at the plant, the sealant was placed on the outside and squeezed out when it was bolted together. They split the rear housing and did it right this time. Refilled with oil, let it sit a few days to monitor it, and no leaks.
My coolant leak I've mentioned in other posts was simply a loose clamp. I didn't spend enough time searching for the cause originally because I knew it was going to the dealer.
The lesson I learned on the A/C problem: always check your radiator. I had used the tractor to break apart round bales that we were burning, and the screen and radiator became blocked with ashes. I didn't think to check it because the temp gauge never showed hot, but that was the reason the A/C was shutting down. Quick easy cheap fix (the best kind).
Anyway it's nice to have it back in the barn. It has 54 hours on it now.
/ XR4046HC update #2
Yea my tractor had a similar gasket problem only mine was the transmission. I let it wait till winter when we went on vacation and they fixed it, a bit harder when they have to break the tractor in two. It all worked out no more leak and that is all the warranty items I had.
2017 Ford F-550 Altec AT40G 40ft. Insulated Bucket Truck (A64556)
2017 Ford F-550...
Club Car Emergency Cart (A64557)
Club Car Emergency...
2015 International ProStar T/A Day Cab Truck Tractor (A64556)
2015 International...
2020 CATERPILLAR 289D3 SKID STEER (A65053)
2020 CATERPILLAR...
2011 Chevrolet Camaro Coupe (A64194)
2011 Chevrolet...
PETRATOOLS HAND PUMP SPRAYER (A64278)
PETRATOOLS HAND...
