Xj2025h draft arms pin
/ Xj2025h draft arms pin #1
rich21
Massey Ferguson 4710
Does anyone know of a better solution to installing the pin that holds the draft arms in without having to remove the rear wheel?
/ Xj2025h draft arms pin #2
Never took mine off. What are you up to? Inquiring minds want to know :) Welcome to the forum.
Actually just bought it last Fall and I used the backhoe until a week ago and I removed the backhoe and went to put the three pt linkage on and discovered the pin installation issue. My dealer told me that LS had a fix for that issue for the Mt series but wasn't sure about the xj. I called LS and they said they would get back to me.
/ Xj2025h draft arms pin #4
Maybe jdom has had his off. Here's is his youtube channel: JIMeRIG
- YouTube
Mine stay on with the backhoe on so they have never been removed.
/ Xj2025h draft arms pin #5
With the 125, there is a kit available at additional cost, not sure about the 2025. I found it's not necessary to remove it again to use the BH. The arms raise enough to get out of the way. I use shock cords to hold them up and to the sides. I did have to remove the metal PTO shield though. No 'tube' stuff required.
thanks to everyone for the info. when I bought it the backhoe was mounted and the 3 pt wasn't so I will install the 3 pt. and try to hook up the backhoe with it on minus the pto shield it sounds like.
/ Xj2025h draft arms pin #7
If the pin is off, to initially install it requires wheel removal. Once its on, the three point linkages can be removed by taking the retaining clips off both sides of the pin. Slide it all the way to one side and the opposite side linkage will drop off. Slide it all the way to the other and the remaining linkage will drop off. Slide the pin back to the normal position and reinstall the retaining clips. Leave the pin on- no need for wheel removal again. You can install the backhoe without removing the three point hitch arms but its a pain in the ***. Easier to take the arms off and on and necessary if using Pat's quick hitch as I do.
2019 Jeep Grand Cherokee SUV (A59231)
2019 Jeep Grand...
2022 BOBCAT MT100 STAND-ON SKID STEER (A60429)
2022 BOBCAT MT100...
2014 International WorkStar 7300 4x4 Altec AA55E 55ft. Material Handling Bucket Truck (A60460)
2014 International...
2018 KAUFMAN 44 FT CAR CARRIER TRAILER (A59905)
2018 KAUFMAN 44 FT...
PALLET OF SAFETY BOUNDARY (A60432)
PALLET OF SAFETY...
2019 INTERNATIONAL 4300 26FT NON CDL BOX TRUCK (A59905)
2019 INTERNATIONAL...
