x495 snowblade question
/ x495 snowblade question #1
colox495
x495
I have a x495 had in the past a 318 with a snowblade was wondering what is the difference in the blades from the 318 to the one for the x495 I can find the 318 blades everywhere but nothing for my tractor, I dont want to spend 1300 for a new blade if a 318 will work, what is the difference and I was told a while back that there was an adaptor kid but no longer???? If anyone can help it would be great as I am tires of searching the web for an answer. Thank
/ x495 snowblade question #2
:welcome:
You will need the quick hitch to use the 318 blade on the X495, or will just need to fabricate the attachment. Was your 318 blade hydraulic lift and angle built-in, or manual?
On my 318 it was all hydro with up and down and left and right. I was wondering if it would fit, they seem to hook up the same when I look at my x495 bracket on the front???:confused:
/ x495 snowblade question #4
That sounds good.
Give it a try and see how far off, if any, that it is. Some pics would be great.
Maybe you won't have to fabricate much or change much to get it to work.
/ x495 snowblade question #5
The distance between the frame is narrower on a 318 than a x495. There is few people selling adapters on eBay. There is a lot to changing the width and you may end up having as much in a 318 blade as the correct for tractor blade.
What you need is a blade for a 425/445/455 tractor. The frame is the same but you need to add 90 deg fittings to the hydraulic lines as the quick connects on a 425 are on the opposite side vs a x495. The same is true for the blowers for the 425. You need to swap sides of the lines and get a different drive shaft. Hope it helps
2019 Peterbilt 567 Quint Dump (A62613)
2019 Peterbilt 567...
2024 Schulte 5026 Batwing Rotary Cutter (A63688)
2024 Schulte 5026...
2020 International HX620 Quint Dump (A62613)
2020 International...
2019 Westinghouse WSTBT1503 Wireless Speaker (A61574)
2019 Westinghouse...
(2) CATTLE SHUTE RAILS (A64280)
(2) CATTLE SHUTE...
2013 Nissan NV2500HD Cargo Van (A61573)
2013 Nissan...
