x495 PTO HP
/ x495 PTO HP #1
TimberXX
Platinum Member
Bergen County, NJ
BCS 770 Italian 2 Wheel Tractor, Grillo 107d, BCS 853, Deere x350, Deere x730
What is the PTO HP of x495?
/ x495 PTO HP #2
Probably in the neighborhood of 20.
Whatcha hooking up?
/ x495 PTO HP #3
On lawn and garden tractors, they don't rate them in "PTO" hp because rarely is a pto used on those tractors, and most of the time they are gas engines. I don't actually remember the hp on that tractor, but gross was @ 24-25.
/ x495 PTO HP #4
Yes they do rate pto horse power, it is 18! Don't answere with assumptions if you simply don't know!
/ x495 PTO HP #5
I don't believe the specs. and literature actually showed PTO hp. Yes, that is a Yanmar diesel and would have both ratings, just wasn't published.
On compacts, yes both hp ratings were used but not on the L&G tractors.
/ x495 PTO HP #6
17, 18 was about right. The X495 handled a 4' rotary cutter "fair" if just cutting pasture, weight was more of an issue than anything. handled the 624 tiller pretty darn good though.
/ x495 PTO HP
My buddy want to hook up a PTO generator, but not the overpriced deere one.
Thanks for the help guys
/ x495 PTO HP #8
I believe the Deere pto gen has been discontinued anyways so only units already on the ground would be available. Possible opportunity to save though is someone is sitting on one.
/ x495 PTO HP #9
It has 18 PTO HP and it is published in some of the JD literature.
John M
2001 Peterbilt 379 Tri-Axle Dump Truck (A59230)
2001 Peterbilt 379...
2022 John Deere 5055E (A62177)
2022 John Deere...
AUCTION STARTS HERE @ 9AM (A65053)
AUCTION STARTS...
2012 CATERPILLAR D8T HIGH TRACK CRAWLER DOZER (A65053)
2012 CATERPILLAR...
John Deere Forks (A64126)
John Deere Forks...
Rotary Auger Motor Attachment (A61572)
Rotary Auger Motor...
