X485 Voltage Outpur
/ X485 Voltage Outpur #1
walleye
cedar rapids, ia
JD X485
Under full Throttle, what is the voltage i should see measuring across the battery?
/ X485 Voltage Outpur #2
After start up I would expect 14.5 volts or so then slowly go down to 12.5 or so.:welcome:
/ X485 Voltage Outpur #3
What Murph is describing is the function of the voltage regulator in response to the battery. If the battery or regulator is failing, you may not see those readings.
Does the x485 actually have an external brake solenoid switch? I see a solenoid switch on the right side that appears to bee part of forward and reverse pedals, but don't see one that is part of safety start switch. i am having trouble when hitting the key and starter not engaging. the brake linkage appears to be a little sloppy. any thoughts out there?
2013 VOLVO A25F 6X6 OFF ROAD DUMP TRUCK (A62129)
2013 VOLVO A25F...
2019 Lynco Mini Mover Aircraft Tug Cart (A64553)
2019 Lynco Mini...
New/Unused Wolverine 78in Quick Attach Land Leveler (A65583)
New/Unused...
2018 CATERPILLAR 326FL EXCAVATOR (A64279)
2018 CATERPILLAR...
2020 Broyhill Load and Pack Articulated Solid Waste Handling Vehicle (A59228)
2020 Broyhill Load...
2017 Ford F-250 4x4 Crew Cab Pickup Truck (A64556)
2017 Ford F-250...
