X485 Voltage Outpur
/ X485 Voltage Outpur #1
walleye
cedar rapids, ia
JD X485
Under full Throttle, what is the voltage i should see measuring across the battery?
/ X485 Voltage Outpur #2
After start up I would expect 14.5 volts or so then slowly go down to 12.5 or so.:welcome:
/ X485 Voltage Outpur #3
What Murph is describing is the function of the voltage regulator in response to the battery. If the battery or regulator is failing, you may not see those readings.
Does the x485 actually have an external brake solenoid switch? I see a solenoid switch on the right side that appears to bee part of forward and reverse pedals, but don't see one that is part of safety start switch. i am having trouble when hitting the key and starter not engaging. the brake linkage appears to be a little sloppy. any thoughts out there?
(1) 40 Yard Roll Off Dumpster and (1) 30 Yard Roll Off Dumpster (A65579)
(1) 40 Yard Roll...
(2) 30 Yard Roll Off Dumpsters (A65579)
(2) 30 Yard Roll...
2017 JOHN DEERE 85G MINI EXCAVATOR (A59914)
2017 JOHN DEERE...
Landhonor ATS-RT15R Mini Excavator (A66285)
Landhonor...
2021 Chevrolet Silverado 2500 HD Royal Service Truck (A64194)
2021 Chevrolet...
New/Unused Landhonor 24in Semi-Automatic Tire Changer (A65583)
New/Unused...
