X340 Transmission Trouble and Help
   / X340 Transmission Trouble and Help #1
jmonte0330
Warwick, NY
Kioti Hst 320 JD X340
My 4 year old lawn tractor just started having trouble on inclines in forward and reverse. I checked the plastic bushings and they are fine. I adjusted the forward pedal to give me more throw in the pedal. Got a lot faster on the level ground but it's still laboring / whining on inclines. More noticeable when it warms up.
It this transmission serviceable?
Any help would be appreciated
Thank you
   / X340 Transmission Trouble and Help #2
Welcome to TBN
How is the oil level?
Through my reading it's sealed? Where do I check. Thanks
   / X340 Transmission Trouble and Help #4
Understand.
Have you been able to check the drive belt, to see if it is slipping or in bad shape?
Thanks beenthere. The belt looks good and does not appear to be slipping.
   / X340 Transmission Trouble and Help #6
So you are thinking all the "slipping" is internal to the transaxle?
When it is going up hill and the forward pedal is 'to the floor', it sounds like a power steering pump that is struggling. whining, etc.
PORTER CABLE 150 PSI AIR COMPRESSOR (A50854)
PORTER CABLE 150...
2020 KOMATSU PC360LC-11 EXCAVATOR (A51242)
2020 KOMATSU...
2022 Gravely Pro-Turn 600 Zero-Turn Mower with 72-Inch X-Factor 3 Deck (A51039)
2022 Gravely...
PALLET OF SQUEEZE OFFS (A50854)
PALLET OF SQUEEZE...
2013 JOHN DEERE 470G LC EXCAVATOR (A51242)
2013 JOHN DEERE...
2009 CATERPILLAR 420E BACKHOE (A51406)
2009 CATERPILLAR...
