X340 Transmission Trouble and Help
   / X340 Transmission Trouble and Help #1
jmonte0330
Warwick, NY
Kioti Hst 320 JD X340
My 4 year old lawn tractor just started having trouble on inclines in forward and reverse. I checked the plastic bushings and they are fine. I adjusted the forward pedal to give me more throw in the pedal. Got a lot faster on the level ground but it's still laboring / whining on inclines. More noticeable when it warms up.
It this transmission serviceable?
Any help would be appreciated
Thank you
   / X340 Transmission Trouble and Help #2
Welcome to TBN
How is the oil level?
Through my reading it's sealed? Where do I check. Thanks
   / X340 Transmission Trouble and Help #4
Understand.
Have you been able to check the drive belt, to see if it is slipping or in bad shape?
Thanks beenthere. The belt looks good and does not appear to be slipping.
   / X340 Transmission Trouble and Help #6
So you are thinking all the "slipping" is internal to the transaxle?
When it is going up hill and the forward pedal is 'to the floor', it sounds like a power steering pump that is struggling. whining, etc.
2018 FREIGHTLINER 1085D DUMP TRUCK (A51406)
2018 FREIGHTLINER...
2012 DRAGON 130 BBL STEEL VACUUM TANK TRAILER (A50854)
2012 DRAGON 130...
2008 Ford F-250 Reading Service Truck (A50323)
2008 Ford F-250...
2011 ORTEQ ENERGY SERVICES 40 MANIFOLD TRAILER (A50854)
2011 ORTEQ ENERGY...
Unused 2025 CFG QK18R Mini Excavator (A49461)
Unused 2025 CFG...
Set of Ag R4 Wheels and Tires (A51039)
Set of Ag R4...
