X340 Transmission Trouble and Help
   / X340 Transmission Trouble and Help #1
jmonte0330
Warwick, NY
Kioti Hst 320 JD X340
My 4 year old lawn tractor just started having trouble on inclines in forward and reverse. I checked the plastic bushings and they are fine. I adjusted the forward pedal to give me more throw in the pedal. Got a lot faster on the level ground but it's still laboring / whining on inclines. More noticeable when it warms up.
It this transmission serviceable?
Any help would be appreciated
Thank you
   / X340 Transmission Trouble and Help #2
Welcome to TBN
How is the oil level?
Through my reading it's sealed? Where do I check. Thanks
   / X340 Transmission Trouble and Help #4
Understand.
Have you been able to check the drive belt, to see if it is slipping or in bad shape?
Thanks beenthere. The belt looks good and does not appear to be slipping.
   / X340 Transmission Trouble and Help #6
So you are thinking all the "slipping" is internal to the transaxle?
When it is going up hill and the forward pedal is 'to the floor', it sounds like a power steering pump that is struggling. whining, etc.
KUBOTA RTV X1100C UTV (A51406)
KUBOTA RTV X1100C...
Mitsubishi FG35 Forklift - 8,000lb Lift Capacity, LP Gas (A51039)
Mitsubishi FG35...
2018 Toyota RAV4 Hybrid XLE AWD SUV (A50324)
2018 Toyota RAV4...
Unused Delta Crash...
2002 Ford F-650 Crew Cab Dump Truck (A48081)
2002 Ford F-650...
1273 (A50490)
1273 (A50490)
