X320 Chute Removal?
/ X320 Chute Removal? #1
millers1
Eastern - West Virginia
Deere 2210, X320
Just traded the LT155 on an X320. The 320 has the 48" deck with dealer installed mulch kit. The chute really serves no purpose other than getting in the way, with the mulch kit installed.. so I want to remove it.
It looks like the two screws that hold the chute / hinge assembly are sandwiched between the deck and the plastic mulch baffle. Do I need to drop down the baffle or is there an easier way to remove the chute assembly?
/ X320 Chute Removal? #2
Might be easier to remove the hinge pin. Is that feasable?
Just need to get a socket on the two 13mm nuts to drop the hinge bracket. Is that covered above with part of the mulch kit?
Yes, that looks like the problem. The mulch kit covers the heads of the two screws. I guess I can just remove the pin /chute / spring and leave the bracket in place.
Heh.. turns out they were carriage bolts, so the chute came off easy enough. Just realized I put this in the wrong forum.. :ashamed:
/ X320 Chute Removal? #5
Glad you got it off.
That is the first thing that comes off my decks.
Distributes the grass better and can mow closer on that side.
And the risk is known, that objects can fly.
I really don't think stuff can fly much with the mulch kit in place. Now someone has to come up with a plate to finish off that side of the deck. Looks stupid with that black plastic mulching baffle there. Maybe I'll get around to making a plate...
Corral Walk-through Gate (A66408)
Corral...
INOP/NON-RUNNING 1957 B61 Mack (A65563)
INOP/NON-RUNNING...
Frontier 10ft. 3 Point Disc (A65640)
Frontier 10ft. 3...
2006 GREAT DANE 48' T/A FLOAT TRAILER (A65643)
2006 GREAT DANE...
2001 WORKHORSE CONVERTED TO FOOD TRUCK (A59914)
2001 WORKHORSE...
Michelin Mach X BIB 710/70R42 Tires (A65640)
Michelin Mach X...
