X304 Pedal Adjustment
/ X304 Pedal Adjustment #1
jpover
East Texas
John Deere / X304
Friends,
My X304 was a bit slow so I adjusted the pedals to give additional vertical movement (video link below). While the adjustment worked great and gives more speed in forward and reverse, now my PTO / blades won't engage. Any advice on how to fine tune the adjustment to allow the blades to engage?
John Deere X3 & X5 Sereis Tractors: Slow In Forward Or Reverse - YouTube
Since there is a safety feature built in to kill the blades / turn the PTO off when going in reverse I assume there is a tolerance of adjustment in one or both pedals to allow the PTO to engage and the safety feature to function.
Update: I was able to fix the above issue by adjusting the rear pedal slightly higher. Now the PTO works with no issue and I have ground speed that's similar to factory settngs.
Thanks,
Joe
/ X304 Pedal Adjustment #2
Suspect you changed the RIO switch position and need to locate it.. and re-position so it is making the necessary connection.
Thanks for the good info. I was able to get the PTO working by adjusting the rear pedal to sit a little higher.
2019 FREIGHTLINER WATER TRUCK (A58214)
2019 FREIGHTLINER...
2002 TOYOTA 7FDKU40 FORKLIFT (A57880)
2002 TOYOTA...
(6) 18X8.50-8 GOLF CART TIRES (A60430)
(6) 18X8.50-8 GOLF...
30 INCH TOOTHLESS BUCKET FOR MINI EXCAVATOR (A58214)
30 INCH TOOTHLESS...
2020 Chevrolet Silverado 1500 4x4 Crew Cab Pickup Truck (A59230)
2020 Chevrolet...
2025 Ford Transit Cargo Van (A56858)
2025 Ford Transit...
