X304 Pedal Adjustment
/ X304 Pedal Adjustment #1
jpover
Member
East Texas
John Deere / X304
Friends,
My X304 was a bit slow so I adjusted the pedals to give additional vertical movement (video link below). While the adjustment worked great and gives more speed in forward and reverse, now my PTO / blades won't engage. Any advice on how to fine tune the adjustment to allow the blades to engage?
John Deere X3 & X5 Sereis Tractors: Slow In Forward Or Reverse - YouTube
Since there is a safety feature built in to kill the blades / turn the PTO off when going in reverse I assume there is a tolerance of adjustment in one or both pedals to allow the PTO to engage and the safety feature to function.
Update: I was able to fix the above issue by adjusting the rear pedal slightly higher. Now the PTO works with no issue and I have ground speed that's similar to factory settngs.
Thanks,
Joe
/ X304 Pedal Adjustment #2
Suspect you changed the RIO switch position and need to locate it.. and re-position so it is making the necessary connection.
Thanks for the good info. I was able to get the PTO working by adjusting the rear pedal to sit a little higher.
Unverferth 275 (A64126)
Unverferth 275...
Case IH 5100 (A64119)
New/Unused Wolverine 84in Quick Attach Smooth Bucket (A65583)
New/Unused...
New/Unused Landhonor Quick Attach Pallet Forks (A65583)
New/Unused...
213101 (A64276)
213101 (A64276)
Rake Master CR-72G (A64119)
Rake Master CR-72G...
