wrlong valve help
/ wrlong valve help #1
oscar94
I posted this in the kubota section but thought i might get some help here too.
I have an L5030 with a LA853 fel and want to hook up the wr long valve and grapple. I am not sure which hose to disconnect from the tractor and connect to the P side on the WRLong valve.
Here is a picture of the hoses. One of these must be disconnected and reconnected to the WRLong valve. Don't know if it is the top or bottom one. Also a pic of the valve on the fel if that is easier to tell.
Also...anyone have any hints on how to route this little hose from the valve body on the tractor to the T side of the WRLong valve? Seems like it needs to bend quite a bit.
If anyone has any pics of their own set up and want to email it to me I would welcome it!!
thanks
/ wrlong valve help #2
The hose you need to disconnect will go to the loader valve's IN or P port, not sure which one that is on the manifold.
The proper forum to post in would be "Hydraulics", not this one or the Kubota forum.
/ wrlong valve help #4
thanks
Search my name. If the hydraulics are the same as the M5400, I posted pictures with labels for the various hoses, inputs and outputs. It may be helpful. You may need to go back a year or two to find it.
I'm on a new computer or I would repost them for you today.
/ wrlong valve help
Thanks doc..I will look for them.
/ wrlong valve help #6
Oscar if you don't find what you need here call Neil at WR Long. I am sure he can talk you through it and has always been great with customer support.
MarkV
/ wrlong valve help #7
The flow needs to go from the Power Beyond Port to the "P" port and then out the "T" port. On all of the Kubota valves that I've seen there is a green mark, green piece of tape, or something green indicating the power beyond port. Remove the Hose connected to the Power Beyond Port and connect it to the "T" port on our valve. Connect the hose in the kit to the power beyond port on your loader valve and the other end to the "P" port on our valve.
Nelson
/ wrlong valve help #8
I've been called Norman, Ned, Neil, Nathan, but my Wife's favorite is Newton.
Thanks,
Nelson
MarkV
/ wrlong valve help #10
If you don't get it figured out, let me know and I'll take some pix ...I have an L4330 and 853 w. the Long valve on it.
EZ-GO Electric Golf Cart (A60462)
EZ-GO Electric...
UNUSED 2026 INDUSTRIAS AMERICA HYD TITL TRAILER (A60430)
UNUSED 2026...
2016 Peterbilt 579 Day Cab w Hydra Flow Setup (A62613)
2016 Peterbilt 579...
2021 Ford F350 XL (A57148)
2021 Ford F350 XL...
JOHN DEERE 624K WHEEL LOADER (A58214)
JOHN DEERE 624K...
Electric Concrete Mixer (A61166)
Electric Concrete...
