WR long third fuction
/ WR long third fuction #1
Chieftm2
Dk4510
I went to take my loader off my Kioti Dk4510 today and I realized that the two lines from my third fiction are threaded into the valve which is bolted under the joystick. I’m just trying to figure out how to remedy this. Should there be couplings there ? Did the previous owner screw up and bolt the valve to the tractor side instead of the loader side? Any help would be much appreciated.
/ WR long third fuction #2
Sounds like you need to install quick disconnects in the two lines going out to 3rd function on the loader similar to what is on the other four lines from loader valve going out to loader
Do you know what male threads I need for that valve body? I guess I’m going to have to find some sort of male to male adaptor to screw the coupler on too?
/ WR long third fuction #4
No I do not. Possibly post some pictures of what you have and we can assist in identifying what you currently have.
/ WR long third fuction #5
Call WR Long and ask them about the threads. It's been a while, but when I called they picked right up and had answers to all my questions.
2015 PETERBILT 567 6X4 T/A DAY CAB TRUCK TRACTOR (A66091)
2015 PETERBILT 567...
2003 Dodge Ram 4x4 Ext. Cab Pickup Truck (A59230)
2003 Dodge Ram 4x4...
2023 Kubota Z412KW Zero-Turn Mower with 3-Bag Bagger System (A63689)
2023 Kubota Z412KW...
Bale Ring (A66408)
Bale Ring (A66408)
2013 PETERBILT 367 (A65643)
2013 PETERBILT 367...
CASE INTERNATIONAL 3330 HI-CYCLE SPRAYER (A63291)
CASE INTERNATIONAL...
