Would you buy another PT?
   / Would you buy another PT? #41
I quoted Brin because he and I have running ribbing session for the past year or so, that's all. We're having a good laugh.
Let's you and I have a good laugh, too. Some day, perhaps, we'll meet for a beverage and shake hands, eh? :)
   / Would you buy another PT? #42
No worries here. Just following your lead. :)
   / Would you buy another PT? #44
I have been looking forward to replacing my PT 422 with a 425, but the 422 is doing too well. I don't think it has been mentioned, if I get a 425 I can use my same attachments. I have as much money in them as in the 422. Also I don't really think that there is another machine that will do what my PT does.
   / Would you buy another PT? #45
...Its a cool machine. Problem is that your built in puckerometer will fail way before the tractor will...
The first PT I ever saw had the dual wheels and a post driver mounted on it, thought it was cool so I looked them up online and couldn't believe they are made just up the road from here.
I'm a steep slope junky. Nothing puts a bigger smile on my face than bush hogging the nastiest mess of briars off a hill side.
   / Would you buy another PT? #46
Then you better go buy one. Nothing is funner than stepping off your machine and tumbling down the hill... Or worse, getting off, going down the hill to deal with an issue and then having to hike back up to the machine. The realization of what a 30 or 40 degree slope is like is an eye opener. But based on your 9540 could you put dualies on? That would be a slope mowing machine. Wouldn't want to lift anything up but...
   / Would you buy another PT? #47
I have to admit, i was put off when i first saw one. You know, not a real tractor, looking like a golf cart etc. After tipping up on two wheels using a couple different tractors i decided to look these over better. Now i'm glad i made the decision to get one. On top of the stability, the articulation and it's ability to climb up and over logs, it is by far the best fit for what i need it to do. I love my "little" PT.:D
   / Would you buy another PT? #48
I, too, was worried about the ground clearance when compared to conventional tractors. But what a lot of folks don't realize is not only does it articulate left and right, it oscillates between the front and rear sections. When you encounter and obstacle, like a log, you can drive the left front tire up on it, and when you turn the wheel all the way to the left, it closes the gap between the two left tires to where they're only a few inches apart. Since the bottom of the unit is essentially entirely a skid plate, you just slide over stuff. I've only hung it on a log one time in 12 years. It was a wet log and my turfs peeled the bark off of it. The far side of the log was also a drop off, so I couldn't push down with the FEL to raise the front up enough to back over the log. So I grabbed the chainsaw, cut a chunk of log, put it under the mower deck, lowered the mower onto it and pushed myself back off of the log. :thumbsup: And, again, I was in a place that I never could have gone with my IH. It was deep into the woods between narrow gaps in trees on a sandy ridge with a too steep side slope for that big tractor. If I was just dedicating the machine to the woods, I'd get larger wheel motors for more torque and tires with larger tread, and, perhaps tire chains. But for now, its the perfect do-all machine for my varied chores.
   / Would you buy another PT? #49
Where was I being nit picky???
I meant you were being nit picky by basing most of your disagreement with Moss's post on his use of the word formidable. My response to you was to show that the word "formidable" (using the definition provided by Moss) could be considered correct... using your own words.
My opinion is based on it's configuration. I believe my Yamaha Rhino has more underbelly clearance. It appears to be a very capable machine on relatively level and smooth terrain.
Your comparison to the Rhino makes absolutely no sense whatsoever... :confused:
I certainly do not think my tractor is formidable. I never made any comparisons between either of my tractors and the PT. Would you like to have that comparable discussion between my tractor and your PT??
I'm confused again. What would the discussion be about? Whether your tractor would be better than mine for what I need it to do? You would certainly lose that one. Unless you meant you wanted to discuss which tractor is "formidable", but that would be silly since you just admitted that you don't think yours is...
So you agree then that formidable might not be the right descriptive word for the PT?
No I don't agree. If you re-read my previous post I said that it could be a word used to describe the PT, it just wouldn't be the first one that comes to my mind. :rolleyes:
Listen, we are all relatively intelligent people here. When someone who is not a PT owner posts his opinions in the "Would you buy another PT" thread, their motivations are going to be suspect. If you don't own one, why come in here and debate which words should be used to describe it? IMO, the "tone" of your response sounded condescending, whether intentional or not, and my guess is that you believe your tractor is a "real" one, and the PT is a neat "little implement".
TBH Moss' use of the phrase "Corvette syndrome" doesn't sound too far fetched to me. :thumbsup:
   / Would you buy another PT? #50
Most of my neighbors have tractors. They borrow my services for my PT many more times than I borrow theirs. The attachments are reasonably priced and effective. They are easy to swap out and I will often change attachments several times during one project. I never did this when I had a conventional tractor.
For pulling and plowing a conventional tractor is superior.
Husqarvana 46in Riding Mower (A56859)
Husqarvana 46in...
2024 Bobcat T770 (A53317)
2024 Bobcat T770...
2011 Toyota Camry Sedan (A56859)
2011 Toyota Camry...
ST225/75R15 Trailer Tires (A55788)
ST225/75R15...
2014 Ford Transit Connect Cargo Van (A55852)
2014 Ford Transit...
2010 MAXEY WELDING 20 T/A GOOSENECK TRAILER (A58214)
2010 MAXEY WELDING...
