Would like honest suggestions about tow vehicle issues
   / Would like honest suggestions about tow vehicle issues #231
My '05 Dodge has been good to me (5.9 Cummins, NV5600 six-speed, B&W goose, 4WD, Jake, etc.). I run an Edge E-Z Tow module along with a Westach dual EGT/Boost gauge and Schaeffer's lubes and fuel treatment. Running around with an empty truck right now (mostly county roads and under 60mph) and the overhead is showing 22.1 mpg so :dance1:
I'd advise you to put a piece of duct tape over the overhead, except it does give temp and your compass. I'm running an Edge chip also and it makes the overhead miss by a mile. I'd also say my overhead reads about 22 mpg also, but I'd bet my hand calculated average is much closer to about 15.5 mpg.
   / Would like honest suggestions about tow vehicle issues #232
   / Would like honest suggestions about tow vehicle issues #233
This seems to be true on the Dodges. My Fords, GM's, Nissan, BMW, Honda, and Toyotas have never been off more than .5 mpg.
Chris
   / Would like honest suggestions about tow vehicle issues #234
yep mine reads at or above 27 on the LIE O METER to end up with, a true hand calc 22mpg, and that's ALL highway and passengers only- No towing, and a concerted effort to minimize fuel use, under 68mph and certainly don't get that every tank,
Now that winter blends are here i guess i can kiss that mileage good by to:laughing:
   / Would like honest suggestions about tow vehicle issues #235
Yes duct tape will fix "your truck" not my truck it's chev dodges need alot duct tape
   / Would like honest suggestions about tow vehicle issues #236
My GMC mileage meter is almost dead on accurate when compared to hand calculating.
   / Would like honest suggestions about tow vehicle issues #238
The problem with a diesel is when you chip them or tune them, often the overhead meter gets thrown off.
   / Would like honest suggestions about tow vehicle issues #239
I find that gm and chevs are good luck
   / Would like honest suggestions about tow vehicle issues #240
03 cummins, 19MPG no matter what I do with it. Bone stock. 2 jeeps on a goose from C Springs to Moab 15MPG. Mojor Maint since new? Valve adjustment and radiator hose and a water pump. Since the cummins is based on a commercial engine, the water pump was a 20 minute job and looses very little anti freeze when you pull the pump. Its 3 bolts and a belt. Now that I have figured out to let Cummins do maint on it, its cheaper than dodge and they know what the **** theyre doing.
Heavy-Duty 3-Point Bale Spike - Efficient Hay Handling for Tractors (A52128)
Heavy-Duty 3-Point...
John Deere 16 Row Cultivator (A50514)
John Deere 16 Row...
2013 UTILITY VS2DX 53FT DRY VAN TRAILER (A51222)
2013 UTILITY VS2DX...
2006 KOMATSU D41P-6 CRAWLER DOZER (A51222)
2006 KOMATSU...
2008 International CF500 Electric Lift Service Truck (A48081)
2008 International...
2022 30ft 20k Blazer Deck-Over Trailer (A52128)
2022 30ft 20k...
