Would a Root Rake Grapple be best?
/ Would a Root Rake Grapple be best? #1
mark02tj
Veteran Member
Southwest Ohio
2005 JD 3520
Apologies in advance for the length of this! :)
I need some advice from the more experienced and super-smart TBNer's! In southwest Ohio we are cursed with an invasive shrub called honeysuckle. My woods (as well as most of the woods around here) are infested with this stuff. It encroaches into the yard and also chokes out everything else including the trees. If you mow it down, it just comes back so the preferred method of removal is to get the roots as well. The stuff in my woods ranges from pencil thin up to trunks that are 8+ inches in diameter. Here is a picture of some of the woods. You can see the honeysuckle brush as well as a lot of downed trees.
I originally started attacking this stuff by hand using an Extractigator. It works well for the smaller stuff, but anything bigger than 1.5" really takes some effort to pull out. So, I moved on up to a Brushgrubber HD using a strap and pulling it out with my Jeep (before I bought my tractor). This also works well but it is a pretty slow process as you're pulling these out one at a time and getting in and out of the Jeep (or on and off the tractor).
As I was looking for a tractor to buy I came across a couple of other options: 1) the Brushgrubber Tree/Post Puller and 2) the BucketSolutions Post Puller. Downside of the Brushgrubber model is that it requires the use of a set of forks in place of the FEL so that would be an added cost. Downside of the BucketSolutions model is that mounts out kind of far so I'd be worried about damage to bucket if I was really torquing it to pull something out as well as a limit to the amount of pulling/lifting force I could get mounted that far out. That led me to finding someone in the implement fabrication business that quoted me $900 to build me something similar that would mount in place of the bucket on the FEL. I didn't think that was a bad deal and was planning on going that direction.
Then I made the mistake of starting to read stuff on TBN and I learned about root rakes with grapples! :laughing: Obviously I'm second guessing my original plan on what to buy. Fortunately I haven't pulled the trigger on anything yet - except my tractor. I came across this thread on TBN where txdon started looking for a root grapple to buy. He eventually ended up settling on one from TheRakeShop.com. See posts 108 and 109 in the thread for his pics. I had seen those even before reading that thread and really liked the fact that the teeth on their rakes go all the way back and don't have a support brace that runs through them like so many other rakes.
So, here is a list of questions:
1) In general, is it easier to pull stuff like honeysuckle from above or from below? Honeysuckle is a relatively shallow rooted plant but the roots do tend to spread.
2) Has anyone used either the Brushgrubber Tree/Post Puller or the BucketSolutions Post Puller or anything similar? If so, can you share your thoughts?
3) If a root rake grapple is the way to go, am I better off to go with a more narrow tool with teeth spaced more closely or go the same width as my FEL bucket (60" on a Deere 300CX loader)?
4) If I go narrower, is it better to have one grapple jaw or two?
5) If I go narrower, am I going to regret that decision when it comes to picking up the fallen trees in the woods?
6) Is anyone familiar with other root rake builders that use the "no brace" design that The Rake Shop uses?
7) Does anyone have any other advice or input that I haven't considered?
THANKS in advance for any advice that you can share!! Again, my apologies for getting long winded on this post. But, I'm trying to make the best purchasing decision that I can. Obviously I can't buy one of everything to try it out - well, at least not until I start playing the lottery! :laughing:
/ Would a Root Rake Grapple be best? #2
Apologies in advance for the length of this! :) Better too long than too short! :D
1) In general, is it easier to pull stuff like honeysuckle from above or from below? Honeysuckle is a relatively shallow rooted plant but the roots do tend to spread. That depends on your equipment.
2) Has anyone used either the Brushgrubber Tree/Post Puller or the BucketSolutions Post Puller or anything similar? http://www.tractorbynet.com/forums/attachments/277824-tree-puller.html
If so, can you share your thoughts?, I have a Brush Grubber BG-20, too slow and too heavy at 36 pounds, to use for very long.
3) If a root rake grapple is the way to go, am I better off to go with a more narrow tool with teeth spaced more closely or go the same width as my FEL bucket (60" on a Deere 300CX loader)? At least 60" :2cents:
4) If I go narrower, is it better to have one grapple jaw or two? One.
5) If I go narrower, am I going to regret that decision when it comes to picking up the fallen trees in the woods? No, lift at the balance point.
6) Is anyone familiar with other root rake builders that use the "no brace" design that The Rake Shop uses? The Gorrila Grapple 10 tine narrow and Faver.
7) Does anyone have any other advice or input that I haven't considered? Try this on your 3 point hitch.
Buckthorn Puller - Custom built Skid Steer attachments to fit almost any need you may have.
Answers above.
Question #5, narrow grapple 44" wide, notice that the top tines are up.
/ Would a Root Rake Grapple be best? #4
I think you would want a "no brace" design to allow the tines to sink in a little better. I prefer a single lid for grubbing out brush because the center of the grapple is covered better. I have a BoDozer grapple and it works great for honeysuckle. I don't think you need to go as wide as the wheel track...it would be nice, but may get a little too heavy for the 300cx.
Here is a picture of my BoDozer with a honeysuckle in the jaws.
THANKS for the replies!!
Xfaxman -> It looks like you've got a ton of experience in removing trees/brush! Thanks for the links and pics!!
binidian -> Hi Brandi! I had already read txdon's quest for the perfect grapple. Good stuff!! That thread is what really started pushing me towards a root grapple instead of the options I'd looked at previously. I also saw and read the link you posted on the auxiliary hydraulic controls - more good stuff! It sounds like you'd be a pretty handy person to have around!
arlen4720 -> That BoDozer is a stout looking tool! Since you've posted the pics, I've read some other reviews on it here on TBN and a couple of other sites. Everyone seems really happy with their purchase. I do appreciate the pics as you've shown me that a root grapple will work well on honeysuckle.
Right now I'm leaning towards a root grapple from The Rake Shop - much like txdon's. I'm am going to call them and Faver to see what the damage to my wallet is going to be.
THANKS AGAIN for the replies and advice!!
/ Would a Root Rake Grapple be best? #6
Be sure you ask them how much it weighs.
My little one is 946 pounds.
The 6' wide Monster Grapple is 1184 pounds.
/ Would a Root Rake Grapple be best? #7
Therakeshop 60" grapple I have weighs 700 pounds with pallet. Faver grapple was more expensive and at this time has a 8 week lead time and the shipping was twice as much as therakeshop. Faver would not make any changes to their grapple but the rake shop is the only one I found that will build what you want. I added 1" tines (up from 3/4") and added an extra tine making the bottom tine spacing 6 1/2". After I ordered it they were shipping it in a week and a half.
/ Would a Root Rake Grapple be best? #8
Mark02tj,
Thanks and Your welcome. There are a few folks that find me pretty handy to have around. My daughter being at the top of that list.
FYI.........If you ever saw logs into lumber, I am told a flat bottom grapple is best. Less board corner gouging than a curved tine grapple.
hugs, Brandi
/ Would a Root Rake Grapple be best? #9
Try Pathfinder 2 spray it and forget it.
/ Would a Root Rake Grapple be best? #10
/ Would a Root Rake Grapple be best? #12
Sorry to resurrect an old thread, but had a relative question. We're getting a new tractor. Pretty much settled on a new Mahindra 3016 with appropriate hydraulics to run a root grapple. We've got a coupla acres to clear of a bunch of scrubby undergrowth. Mostly stuff in the 1-3" range in sandy soil. I've read a few of the threads about using the root grapple to get this done. Seems like I saw guys with smaller grapples and small-ish tractors gettin this done. One of the dealers I was checking into said that in no way should a front end loader be used like this. Don't know what to believe.
Anyways, seems like most guys were recommending the WildKat E-series root grapple.
My questions are. Is the 28HP Mahindra enough tractor to get that done. And does the Wildkat 48" E series grapple still the most bang for the buck? I'm only a coupla hours from them and that would be very handy.
Thanks in advance for any helpful info. d:^) Schneeks..
2018 Dodge Charger Sedan (A61569)
2018 Dodge Charger...
5ft 3 Point Hitch Rotary Cutter (A61166)
5ft 3 Point Hitch...
2024 John Deere 6R 130 Tractor Loader (A63109)
2024 John Deere 6R...
23" QUICK ATTACH EXCAVATOR BUCKET (A60429)
23" QUICK ATTACH...
2009 John Deere Z925A Zero Turn (A63116)
2009 John Deere...
2021 Dodge Durango SUV (A61569)
2021 Dodge Durango...
