Would a 12' trailer haul a Bobcat CT2035/Kioti CK3510 with loader?
   / Would a 12' trailer haul a Bobcat CT2035/Kioti CK3510 with loader? #1
sheamus
Upper New Cornwall, NS
Bobcat CT2035HST
I have a line on a 12' tandem trailer with brakes. It is a fair ways away, and before I drive to see it, I am wondering if it would handle my tractor with FEL (Bobcat CT2035). I have used a 14' before, and I think 12 would be tight, but I only haul the tractor a couple times a year, so doesn't have to be perfect. Anyone using a 12' trailer on a tractor this size?
   / Would a 12' trailer haul a Bobcat CT2035/Kioti CK3510 with loader? #2
Here is a picture of my Yanmar 424 on a 12' trailer. I have to take the bucket off and run the loader arms into the bucket to make it fit, so I highly doubt you could put a bigger tractor on a 12' trailer unless you overhang somewhere. A CK3510 shows the tractor itself at around 10' long, while my 424 is only 8'9".
   / Would a 12' trailer haul a Bobcat CT2035/Kioti CK3510 with loader? #3
12 foot is crazy small. I wouldn't want that for free. But I guess if your totally cash strapped and can't get anything better... you make sure with what you can get your hands on. I run a 22' Iron Bull and I don't think it's everything I want. A 24 or 26 foot deck would be better when I have a brush hog on back.
   / Would a 12' trailer haul a Bobcat CT2035/Kioti CK3510 with loader? #4
Built this at 12” but I immediately regretted not going dual and 14’
   / Would a 12' trailer haul a Bobcat CT2035/Kioti CK3510 with loader? #5
Problem with that length is load balancing. I put my bx23 on my neighbors 14' tandem. It barely fit and it was tail heavy. Wasn't a fun haul. I have a 16' tandem now. Wish it was bigger but the tractor and me are 100x safer now.
   / Would a 12' trailer haul a Bobcat CT2035/Kioti CK3510 with loader? #7
What is the trailer load rating?
   / Would a 12' trailer haul a Bobcat CT2035/Kioti CK3510 with loader? #8
I have a ck4010 put it on a tandem 16' trailer with a brush hog and hung off back. Also like the other guy said the weight was to far back and was hard to pull with the loader and bucket. Upgraded to a 25' goose neck and couldn't be happier plenty of room for tractor and attatchments. I would regret trying to put it on a 14' everytime I moved it.
   / Would a 12' trailer haul a Bobcat CT2035/Kioti CK3510 with loader? #9
Also depends on what type of vehicle you are pulling the trailer. I had a 2005 F150 4.6L V8 that I pulled a 18 ft dual axle trailer carrying a 2000 lb implement. I did it but wonder how much strain I was putting on the transmission. I moved up to a 2014 F250 6.7L diesel so I didn't have to worry about what I could pull.
The 18 ft trailer I bought new from Big Tex trailer is as short as I wanted to go. I probably should have move to a 20 ft.
   / Would a 12' trailer haul a Bobcat CT2035/Kioti CK3510 with loader? #10
Here is my ck2610 on a 12ft trailer. It was extremely tight but balancing seemed ok with loaded tires
Toro 30495 Groundsmaster 7200 72in Zero Turn Mower (A48082)
Toro 30495...
66in Light Material Bucket Skid Steer Connection (A51039)
66in Light...
UNUSED INDUSTRIAS AMERICA F08 - 8' LAND LEVELER (A50459)
UNUSED INDUSTRIAS...
2015 F-550 Bucket Truck Gas Engine (A51039)
2015 F-550 Bucket...
Ford Super Duty 8ft. Truck Bed (A49346)
Ford Super Duty...
1999 INTERNATIONAL PAYSTAR 5000 TANDEM AXLE DUMP TRUCK (A51222)
1999 INTERNATIONAL...
