Worst stuck pics
/ Worst stuck pics #103
Ahhh yes raw power of steam.:cool:
/ Worst stuck pics #105
The raw power of several things. The steamer is a bunch heavier, the hitch point was unequal, pulling the JD's rear tires up off of the ground. The JD was not in 4 wheel drive. This was a total show stunt.
/ Worst stuck pics #106
Like it would have mattered if the rope was level and the JD was in 4wd.
/ Worst stuck pics #107
I dont think the steamer was in 4wd either though.:laughing:
In reality, I dont think any of it would have mattered either. Just too much weight
/ Worst stuck pics #108
Yeah, that old steamer is a big hunk of iron, and is "hooked" to the ground pretty well.:)
/ Worst stuck pics #109
In a pulling contest, hp is irrelevant. A 1/2 hp motor properly geared to a heavy vehicle drivetrain will out pull a lighter vehicle every time. It won't pull very fast but it will out pull the lighter/less tractioned vehicle every time.
/ Worst stuck pics #110
10 ft in the air? Really? :rolleyes:
I'll buy 10 feet. I used to run a lugger scrap truck before I retired and when picking up a heavy scrap box, I could bring the front end off the ground 10 feet, no issue. Just had to be careful setting it down so you didn't break a spring.
/ Worst stuck pics #111
Those steamers produce tons of toque, and it's all low end. They produce maximum toque when completely stalled.
/ Worst stuck pics #112
Another weight VS horsepower contest.
Bruce
/ Worst stuck pics #116
I didn't see Jesus anywhere in that video.
/ Worst stuck pics #118
Operating the camera
Ahhh, of course!!
I'm sure the hand of the Almighty had nothing to do with sending that dragline (earth altering machine) into the water, rendering it inoperable, and everything to do with getting it out and back into service.;)
Pretty cool seeing all those dump trucks hitched up, though.
/ Worst stuck pics #119
They said the fleet of trucks weighed 2,400 tons. They must have left off a zero or two.
/ Worst stuck pics #120
80 tons loaded and about 30 trucks. Seems right to me
GENERAC MOBILE PRODUCTS MLT6S LIGHT PLANT (A68842)
GENERAC MOBILE...
3145 (A63117)
3145 (A63117)
2018 Toro Workman Workamn HDX-D Diesel Utility Cart (A66734)
2018 Toro Workman...
2025 Mini Excavator Attachment Set (A66734)
2025 Mini...
2025 GIYI GY-P45 Hydraulic Breaker Mini Skid Steer Attachment (A66734)
2025 GIYI GY-P45...
6 1/4 INCH OD 90 DEGREE ELBOWS (A67714)
6 1/4 INCH OD 90...
