Worm ranching / vermiculture
/ Worm ranching / vermiculture #11
Don,
Broadly, what are the temperature requirements?
Buck
From the manual: the ideal range is 55 - 80 degrees F.
Danger zone: below 40 degrees F or above 90 degrees F.
The bin does come with a primitive heater. It is just
a piece of plywood wrapped with tinfoil and lines with
wires that heat up when you plug the unit in. There
is no thermostat, so you have to plug and uplug the
unit for any effect. Said plywood sheet wrapped in
tinfoil is supposed to have insulating properties for
heat and cold, so you are always supposed to leave it
on top of the compost pile, below the lid. I found
this to be a big nuisance and I didn't really need it
so I quit using it altogether, so far with no ill
effects.
Kubota M4700 4WD 51HP Utility Loader Tractor (A56857)
Kubota M4700 4WD...
2000 Mack CH613 Dump Truck (A59213)
2000 Mack CH613...
ELECTRIC GOLF CART (A58214)
ELECTRIC GOLF CART...
2012 Ford F-250V Ext-Cab Pickup Truck (A59230)
2012 Ford F-250V...
2023  FREIGHTLINER M2 22FT NON CDL BOX TRUCK (A59905)
2023 FREIGHTLINER...
2016 Ford Explorer AWD SUV (A59231)
2016 Ford Explorer...
