Tires Worlds largest turf tires?
   / Worlds largest turf tires?
Certainly should be stable on cross slopes.
Might be prone to sliding though /forums/images/graemlins/blush.gif
   / Worlds largest turf tires? #12
If nothing else you can always use the tractor to roll the lawn. That is if the loading is still high enough!
   / Worlds largest turf tires? #13
</font><font color="blue" class="small">( Looks like the turf tires on the tractor being serviced when I picked mine up. They were on a Kubota used on a golf course and looked at least that wide. Really impressive in person. )</font>
With those babies you could drive on the greens without any damage /forums/images/graemlins/grin.gif
   / Worlds largest turf tires? #14
Mowing turf where tire marks are not acceptable(golf courses ect). The wider the footprint, there's less contact area per square inch. If your 12.6x16 tire puts 50lbs/sq", an imaginary 25.2x16 tire would theoretically cut that contact pressure in half, to say 25lb/sq". Less contact pressuree, less marking.
   / Worlds largest turf tires? #15
</font><font color="blue" class="small">( What is the significance of such a large tire? )</font>
Gerard,
For some reason over there in the UK, they insist on doing things like golf courses etc. on peat fields. Peat is extremely soft.
phil
   / Worlds largest turf tires? #16
I've seen super wide turf tires on sod farms in Northern Indiana.
   / Worlds largest turf tires? #17
bearing on ground, for a pneumatic tire, is the psi you put in the tire ...then, the weight of the vehicle equals the combined area of all the (four) contact patches times the psi ...
   / Worlds largest turf tires? #18
Thanks guys. Gerard
   / Worlds largest turf tires? #19
Kinda makes it look like a hot rod!
   / Worlds largest turf tires? #20
Here's my HOT Rod !! So far I love my turfs although I originally wanted R4's. They do give the tractor a more rugged, heavy duty....ok.... cool look !!
2020 PETERBILT 567 (A58214)
2020 PETERBILT 567...
2018 Honda Odyssey Van (A56859)
2018 Honda Odyssey...
2015 Ford Taurus AWD Sedan (A55853)
2015 Ford Taurus...
Hose Reel (A55787)
Hose Reel (A55787)
Husqvarna 46in Riding Mower (A56859)
Husqvarna 46in...
ASSET DESCRIPTIONS & CONDITION (A57880)
ASSET DESCRIPTIONS...
