Snow Attachments WORKSAVER VS HLA Snow plows
   / WORKSAVER VS HLA Snow plows #11
I have been dealling with Horst since the days you could walk in there and get them to build you something. Now they refer you to a dealer. But I still buy from their stuff. They were heavy built if not a bit crude at times. I think that may have improved somewhat. Tha last bad thing I heard about Horst (HLA) snow equipment was from a displeased customer saying the paint job was of very poor quality. Came off after the fist use.
   / WORKSAVER VS HLA Snow plows #12
I just got my HLA, it is well built and no problems so far other than learning how to use it correctly. The angle of the blade to ground (curl) is very important to avoid digging in. Also, the relief valve works but once it relieves, you must manually return to your previous angle, it will not automaticly return. As mentioned, works better on frozen ground, tends to dig into loose gravel/grass on some farm lanes. I added a third skid, at the rear in center to allow it to sit flat.
   / WORKSAVER VS HLA Snow plows #13
Not familiar with either, and being that they are used plows, even searching their current models may be different.
But I would let the choice come down to brand. Look at each plow. If one of them is a floating plow (by chain or other method) that is a huge plus. Look at other build features and qualities. Dee if something stands out as being superior to the other. Buy the one that is better assuming price is similar.
Once again -- thanks. Got the plow today. Went with the HLA. As you have all said it sure is a rugged piece of gear. I will spend some time tomorrow going over it and looking for any issues I missed. Very well built, great shape - my only concern is that it has fixed shoes. I would much rather have adjustable but it looks like if i fire up the torch and the welder I could change these out. But as soon as we get some new snow I will try it out and see if there are problems with the fixed shoes. They appear to set the blade about 3/8" above the bottom of the shoe. So I am not too concerned.
Thanks again - I will let you know how I like it -
   / WORKSAVER VS HLA Snow plows #15
Interesting! I didn't realize that they had made plows with fixed skid shoes! Like to see a photo... All the HLA plows I have seen (catalog + in person) have stacked spacer shoes.
   / WORKSAVER VS HLA Snow plows #16
Here is link for HLA Snow Blades, they do not make one without adjustable shoes/skids. Maybe you bought an older model or clone? Just saying, my 2000 has adjustable skids/shoes and my friends 1000 also has them. Picture please? HLA Snow | 2000 SnowBlade
DevilDog
   / WORKSAVER VS HLA Snow plows #17
HLA plows are a lot more HD than the worksaver stuff, as others have said there only real fault is the paint job. It seems as though they don't do a great job prepping the bare metal before painting. Given the choice between the two I'd pick the HLA all day long and twice on Sunday.
Matt
   / WORKSAVER VS HLA Snow plows #18
I purchased a HLA 2000 new 4 years ago that had set on the dealers lot and the paint job was bad. I had it painted to match my Kioti and it worked great. I then purchased a new HLA 3000 and have had it for two years and the paint job on this one is holding up much better, it still looks good. Both have similar type adjustable skid shoes.
   / WORKSAVER VS HLA Snow plows #19
..and mine has barely been used this winter. Like buying very expensive snow insurance, currently raining and +8c. I wonder if I can convert it to a squeegie?
Hello Again - I see some questions here on the shoes for the blade. Tomorrow I will grab a few pics. The Snowblade has all the characteristics of an HLA and was sold to me as a Horst Welding snow blade. My assumption was that Horst and HLA were one and the same, but I am only making an assumption on that. I will check this out tomorrow and post photos. Anybody know if and where there would be a model / serial number tag?
2016 FORD TRANSIT 250 VAN (A51406)
2016 FORD TRANSIT...
Unused Delta Crash...
PALLET OF TARPS, UMBRELLAS, AND PORTABLE SHADES (A50854)
PALLET OF TARPS...
2008 KENWORTH T300 CHEMICAL TRANSPORT TRUCK (A50854)
2008 KENWORTH T300...
2003 Big Tex 10PI 16ft. T/A Pipe Top Utility Trailer (A49461)
2003 Big Tex 10PI...
3in Poly Pipe (A49461)
