Working under the tractor
/ Working under the tractor #21
Bears repeating... beware the front axle of a tractor. It pivots, so allows the tractor to tilt. (unless the pivot is blocked) lifting the rear wheels on ramps is much more stable.
/ Working under the tractor #22
I use the bucket (bucket forks) on my tractor for hauling and moving all sorts of things so I've blocked the pivot. It is a bit odd for driving, but a lot safer for the bucket.
The pivot shouldn't matter much if one pulls the tractor up on 4 ramps. But, it could be a pain for jacking and using jack stands. It still would be OK as long as one always keeps both sides of the rear end supported.
I am grateful, gentlemen, for all these good ideas, especially the ramps with detachable parts. Although I suppose I could simply raise the tractor with its own hydraulics, put hefty wood blocks under the rear wheels and jack stands under the frame in front, and lower it. To get back in operation, just reverse the process. However, the ramps would also be useful for the zero turn.
/ Working under the tractor #24
As far as plastic ramps, I would also be skeptical, although I would hope that Eastwood would do some quality control on the ramps they sell. Plastic should be strong if well designed and built.
Plastic Legos for under trailer jacks are common.
As far as the detachable steel ramps. I have an older set that I inherited, probably 20 or 30 years old by now. I don't use them a lot, but it seemed like a good idea for the tractors. The steel Ironton ramps popped up with searches, but may be discontinued.
Buckets are a very handy feature on tractors, but they always get in the way during maintenance. And, for the most part it is better to put the bucket flat on the ground, than lifting it when working on the tractor.
/ Working under the tractor #25
If it must be lifted to work on the tractor be sure to block the lift cylinders so it cannot drop. A piece of angle iron cut so it will lay onto the length of the exposed rod, tied in place is works well for this.
/ Working under the tractor #26
I bought one of these 4 post lifts 10 years ago:
The ramps are adjustable for smaller width vehicles.
Pricey, yes, but they can also be used for storage which frees up valuable floor space.
I now have 3 of these lifts which are used mostly to store implements. This saved the cost of putting up a new building.
/ Working under the tractor #27
Can you straddle a ditch? i.e. poor man’s pit?
/ Working under the tractor #28
Nobody has mentioned a pit. Sometimes methods work best, no falling.
/ Working under the tractor #29
I have just finished another oil, transmission fluid and filters change, and transmission fluid strainer cleaning on my Kubota BX25D. And I have previously done several one-off jobs like relocating that damned fuel filter.
I hate to admit that I'm getting old enough to dislike scooching under there while wrenching, but there it is.
What do you use to raise the tractor enough for comfort, while making sure it's stable enough to be safe? I have a creeper, but this tractor is too low to use it.
I have a floor jack and jack stands, but I imagine it should be level to drain the fluids, and I don't think 4 jack stands feels very stable. I looked at 2-post hydraulic lifts, but they are expensive, and require serious installation, and I'm not sure they even fit a tractor. Digging a pit is out of the question; it would quickly become a pond.
Would 4 ramps from HF or an auto parts store be the answer? I imagine that the total weight with loader and backhoe is about 3k pounds.
I have BX25D. Floor jack and jack stands work fine, completely stable on a hard surface like a concrete floor. Remove backhoe and FEL before jacking up. Yes, the front axle pivots but this is not an issue if the front axle jack stands are set at the same height. Buy quality jack stands. It’s your butt under there.
/ Working under the tractor #30
I use railroad ties cut to about 4' long.
I position the rear ties behind the rear wheels and back the tractor up onto the ties. Use the FEL to raise the front wheels then position the front ties and lower the front wheels onto the ties. Then put the bucket edge down as well as the brake lock on and wheel chocks on top of the ties if necessary.
I also have multiple jacks for further jacking when I need to raise the wheels off the ties.
Use this setup for most servicing tasks... works great.
International 9200 (A61307)
International 9200...
2020 HAMM H7I COMPACT LINE SMOOTH DRUM ROLLER (A59823)
2020 HAMM H7I...
UNUSED PAIR OF MINI RUBBER TRACKS (A52706)
UNUSED PAIR OF...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
DRAGON 500 BBL ACID TANK (A58214)
DRAGON 500 BBL...
2013 Audi A4 Sedan (A55853)
2013 Audi A4 Sedan...
