Working rail roads and their tracks.
/ Working rail roads and their tracks. #3,801
There are disaster videos of slag being dumped from railcars into ditches that were a bit too wet, (puddled?) and resulting steam explosions were pretty scary. Glowing gobs of slag scattered about.
btw, YouTube just suggested a video of an EMD (IIRC) diesel running with the valve cover removed. I might see that again and can post a link. Shoulda seen the circumstances but passed once already. (Doh!)
/ Working rail roads and their tracks. #3,802
Back in the 70s, we hauled a lot of slag aggregate out of the Levy Company and Bethlehem Steel in Gary. When we went into the steel plant to load, there would often be torpedo cars setting on tracks waiting to be loaded or cooling down so they could be relined with refractory brick.
My father got several loads of slag for his driveway when I was a kid. It worked great compared to gravel. So back around 1989 when my wife and I bought our land, I had to cut in a road from the state highway. It's all sand. But I bought a soil map and found a pocket of gravel that was exactly where we were required to make the cut by the state. Pretty lucky. So I dug out the roadbed through the sand 12" down 400' back, lined it with the gravel 6" deep, and brought in multiple tri-axle dump trucks of slag, and spread that on top of the gravel another 6" deep. I've had cement trucks over it with no problems. The sharp edges of the slag lock into each other, yet drain easily. No frost heave. The sand below helps, I'm sure.
Anyhow, back to trains. (y)
/ Working rail roads and their tracks. #3,803
A few years ago, I picked up an Electromotive 645E3 overhaul manual at a flea market. I've spent hours browsing that manual, those engines are amazing pieces of engineering, especially the fabricated, not cast, engine blocks. Although the main bearing saddles and some other parts are cast and welded into the blocks.View attachment 1862549
Just seeing the cover picture sent chills of having to 'dive for pearls' which was changing out a power assembly before the scheduled overhaul period. The 'diving' part was the guy who had to work through the lower access cover to remove the connecting rod cap, the oil 'pee pipe', etc.. Lord forbid if you dropped anything as the oil was not drained from the crankcase. If you dropped anything you would be labeled as unreliable and be assigned any of the worse of the worst jobs until you could prove yourself worthy again. In some cases you would never outlive your new nickname(s). Needless to say the old timers never did that part of the job but one would be watching from the access cover on the other side in case you did drop something. Fortunately a power assembly change-out didn't happen too often.
/ Working rail roads and their tracks. #3,805
Unpowered cab car:
Bruce
/ Working rail roads and their tracks. #3,806
/ Working rail roads and their tracks. #3,807
/ Working rail roads and their tracks. #3,811
/ Working rail roads and their tracks. #3,814
/ Working rail roads and their tracks. #3,815
Almost looks to be sitting on the dirt.
In the woods of Wisconsin, crew pose alongside their charge, Rust-Owen Lumber Company "Ten-Wheeler" number 3. This lovely coal-burning 4-6-0 was built by the Pittsburgh Locomotive Works in 1892, and delivered to the Drummond & Southwestern, which had begun operations in August of 1891 and was absorbed by the Rust-Owen Lumber Company in June of 1912. The logging lines branched out from Drummond, Wisconsin and the final operation wasn't wound down until 1930. There is no date on this photo, but I know that it's post-1910 as that is when the railroad replaced its link-n-pin couplers with standard knuckles. Notice however that number 3 sports the unusual configuration of two different coupler heights on her pilot.View attachment 1798664View attachment 1798665
Very nice. The jug on the forward end of the coal car?
/ Working rail roads and their tracks. #3,817
"Wood car?" :sneaky: Not much coal used in timber country, or West of the Mississippi river. Just as much a water car as a 'fuel' car. (coal, wood, oil)
btw, those scoop-looking things under some steamer tenders are to pick up water from troughs between the rails. (Y'uns knew that. :))
/ Working rail roads and their tracks. #3,818
/ Working rail roads and their tracks. #3,819
There used to be troughs in an area to the west of us between South Bend and New Carlisle, so I'm told.
I guess the problems were they would freeze in winter, soak any passengers with open windows in the front cars, damage windows in adjacent trains, etc...
/ Working rail roads and their tracks. #3,820
Ahhh, I found it! The area is called Terre Coupee, IN. It's a little east of New Carlisle.
A freight train didn't raise its water scoop before it got past the end of the trough, caused a derailment, and a passenger train was struck going in the opposite direction. No fatalities. Very interesting description and diagrams, for those so inclined to read it. (y)
ALLMAND NIGHT-LIGHT PRO 4 BULB LIGHT PLANT (A52706)
ALLMAND...
Grove 4x4 Rough Terrain Hydraulic Crane (A55851)
Grove 4x4 Rough...
2013 International WorkStar 7400 4x4 Altec AM650 50ft Material Handling Insulated Bucket Truck (A59230)
2013 International...
2015 Ford F-250 Crew Cab Pickup Truck (A59230)
2015 Ford F-250...
2025 JMR 40in Single Cylinder Brush Grapple Mini Skid Steer Attachment (A59228)
2025 JMR 40in...
iDrive TDS-2010H ProJack M2 Electric Trailer Dolly (A59230)
iDrive TDS-2010H...
