Working rail roads and their tracks.
   / Working rail roads and their tracks. #3,691
If you lift the operating lever without the pin the knuckle falls on the ground a real nice surprise in the middle of the night
   / Working rail roads and their tracks. #3,692
Why not put dynamic grids on the tender, fed by the drivers turning that big electric motor in the cab?
Bruce
True but. UP keeps a diesel locomotive in the consist to power the cars. While 4014 has an onboard generator powered by steam, it's no where large enough for auxiliary car power.
   / Working rail roads and their tracks. #3,693
I would like to see a modernized E-7/9 B-unit to be the locomotive traveling with it so as to not break up the lines of the passenger cars.
Bruce
This mornings pellet train coming into Silver Bay MN. 10-01-24. Love those colors.
Cool mornings make for pellet car steam! It's 46 degrees in Culver MN but the trees aren't fooled though. Fall color is a week or so behind normal but there has been significant change in the last 3 days making for a nice going-away backdrop for this U717 from Fairlane this morning.
DMIR Southbound ore loads with engines SD40-3 408-411 is seen at Wyman, MN; and shortly after Northbound ore empties led by engines SD40-3 418-417 is seen coming and going at Wyman on October 9, 2004. (old pics)
   / Working rail roads and their tracks. #3,699
Interesting video, my doodlebugs were a bit different.
They consisted of old one or two ton trucks rear ends and frames with an engine and usually two transmissions in series to get low geared log jumping off road vehicles to run around on logging woods roads. usually no cabs and old tires chained up with a weight box on the rear full of rocks for traction.
UNUSED SDLANCH SDLL60 STAND ON SKIDSTEER (A57192)
UNUSED SDLANCH...
TANK MANIFOLD (A58214)
40' CONTAINER (A57192)
2023 Kubota L6060HST Compact Utility Tractor (A55315)
2023 Kubota...
2015 Ford F550 (A55973)
2015 Ford F550...
2025 Wolverine MAD-12-12D 36in Auger Skid Steer Attachment (A55851)
2025 Wolverine...
