Working rail roads and their tracks.
   / Working rail roads and their tracks.
The RR's have seen deregulation over the years. They have also consolidated which is good for profits but bad for upkeep.
   / Working rail roads and their tracks. #2,702
What, they never took a physics class?
That's the problem.
The beancounters ordering the speedup to be more profitable (successfully) are resisting acknowledging the physical limits that train unions say are the cause. In the cases mentioned, heavy cars in the back half of a huge train can push light empty cars up front right off the track when braking. The article discusses how regulators are ignoring the issue,
   / Working rail roads and their tracks. #2,703
And they blame the train crew for "improper" train handling they are the scapegoats behind the throttle.... always have someone to blame or fire
   / Working rail roads and their tracks. #2,704
Interesting article. They say one problem with trains 1~2.5 miles long is when braking, light empty cars up front get shoved off of curves if most of the weight is in the final third of the train.
The final part of the article has several examples.
I have seen several videos of derailments that were obviously caused by having unladen cars near the front of the train getting pushed off the track by loaded cars pushing them.
Still, I see NS trains that are 1.5 to 3 miles long with empty cars at or near the front of the consist.
Like another poster commented, whoever makes up the roster, never took a class in physics, or doesn't care about the consequences. Sounds to me like they are giving regualtors a good reason for some regulations about where empties are located in a train.
   / Working rail roads and their tracks. #2,705
I expect railcars picked up along the way are easier to attach by uncoupling and sending the locomotive into a siding, rather than backing the 3 mile train into the siding to fetch them.
Picking up unladen cars this way was cited as a cause in one of the accident reports, with the local dispatchers at those points named responsible.
In case anyone cares to see what a draft gear looks like. These take the shock of braking cars.
or
   / Working rail roads and their tracks. #2,707
Maybe the could have a braking system that applies brakes on each car depending on it's weight and speed.
   / Working rail roads and their tracks. #2,708
Yeah, that won't cost much.
   / Working rail roads and their tracks. #2,710
Electrically controlled pneumatic brakes, from:
As previously discussed, for purposes of this updated analysis PHMSA and FRA are using an estimate of $7,800 per tank car to retrofit with ECP brakes.
PHMSA and FRA estimated that 32,582 tank cars would be required to have ECP brakes in the low range scenario. In the high range, 43,430 tank cars would be required to have ECP brakes.
Bruce
2017 Chevrolet Silverado 2500 4x4 Crew Cab Pickup Truck (A55973)
2017 Chevrolet...
2014 Ford Taurus AWD Sedan (A55853)
2014 Ford Taurus...
Deere 350G LC (A53317)
2020 MACK GR64FT (A58214)
2020 MACK GR64FT...
Husqarvana 46in Riding Mower (A56859)
Husqarvana 46in...
Honda utv cart (A56859)
Honda utv cart...
