Work Light Help!
/ Work Light Help! #1
bradv42
Western New York
Kubota B3030 4-Wheel Drive Tractor w/ turf tires
After reading many posts about the need to add higher output alternators to run work lights I may have a solution that may cut down on the need to add the alternators. The product is an LED Work lamp that puts out the same amount of light about 15 watts vs. normal 35 watts (for incandescent). See attached link for more info. I have this lamp and it is impressive.
View attachment 81360NP.pdf
/ Work Light Help! #2
How much were they? They are exactly what I'm looking for.
thanks
/ Work Light Help!
They can be bought through your local NAPA store. He may not have them in stock but they can be ordered.
/ Work Light Help! #5
$90?! That's crazy! It's probably got $15 worth of Luxeon star LED's in it, $6 bucks worht of pcb/resistors/regulators and wires. That means that a very expensive housing :) Not worth the $$$ for me to change over. But thanks for the heads up.
j
/ Work Light Help!
j
Not really that crazy! These worklamps have much more high preformance LED's than the Luxeon star. The product is binned by output and using the highest preforming diodes (lumens/watt) available today on a custom metal core board. The board is sealed in epoxy so that it is virtually bullet proof. With the low current draw and the 5 year warranty. It might be worth a try! Especially if you are faced with the need to add a higher performance alternator!
FYI
Brad
Wheel Loader Forks (A64126)
Wheel Loader Forks...
Saltdogg by Buyers, Slide in Spreader Box (A62679)
Saltdogg by...
2016 Nissan Titan XD Crew Cab Pickup Truck (A61573)
2016 Nissan Titan...
2015 John Deere 6130D (A64126)
2015 John Deere...
2017 Kubota M7-151 Premium MFWD Tractor (A61307)
2017 Kubota M7-151...
New/Unused 3-in-1 Quick Attach Frame (A65583)
New/Unused 3-in-1...
