Backhoe Woods Subframe: Installation on CT230
   / Woods Subframe: Installation on CT230 #11
I got the Woods BH75, but with our wet spring I haven't been able to do much. I ended up building a dolly for it so mounting only takes about 10 minutes.
How about a photo of your dolly. I have the same backhoe. TIA
You can find some photos of the dolly in another older thread in the Build-It-Yourself forum. Here's the link.
I didn't really do any "plans" for the dolly, just mostly "field-engineered" the thing with some casters and a bunch of 1 1/4 square tube. The important thing with a dolly is to make sure the hoe rolls up to the subframe with about 1/4" vertical clearance for the bottom pins of the 4-point mount. That way the pins immediately slip right into the slots when you raise the hoe with the stabilizers. Alignment becomes trickier and more frustrating the greater that initial clearance happens to be.
   / Woods Subframe: Installation on CT230 #13
Link did not work for me.
Link fixed! (I hope)
UNUSED FUTURE 32" HYD TILTING BUCKET (A52706)
UNUSED FUTURE 32"...
24in excavator tooth bucket (A56436)
24in excavator...
2020 PETERBILT 567 (A58214)
2020 PETERBILT 567...
2023 Kubota BX1880V-1 Sub - Compact Utility Tractor with 54-Inch Mower Deck (A56438)
2023 Kubota...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
2018 INTERNATIONAL LT625 TANDEM AXLE SLEEPER (A59575)
2018 INTERNATIONAL...
