Woods Brush Hog Gear Oil
   / Woods Brush Hog Gear Oil #1
Buckchaser
Bradford PA
Massey F 1734
Could anyone tell me what type gear oil is best for an older Woods Brush Hog and also for a King Kutter tiller ?
   / Woods Brush Hog Gear Oil #2
I use 75-140 synthetic in everything
But I do live in ca where it's hot then hotter
   / Woods Brush Hog Gear Oil #3
The Owners Manual for my 1976 Woods M5-4 Rotary Cutter says to use #90 transmission oil (also called gear oil).
   / Woods Brush Hog Gear Oil #4
There are better gear oils now, plus they have a wider viscosity range. 75w-90 would be a good choice. It flows at low temperature a lot like 20w motor oil, but has the shear resistance of a 90wt gear oil.
rScotty
   / Woods Brush Hog Gear Oil #5
75-140 is gear oil just use the synthetic pricey but worth the money
They sell in 80 90 weight also
But use what you are comfortable with
   / Woods Brush Hog Gear Oil #6
older mower seals might be at risk with full synthetic having used dyno all it's life, but that may well be a myth for modern synthetics
but agree, 75/180 syn would cover all the needs, regards
2012 VOLVO DBL SLEEPER ROAD TRACTOR (A51247)
2012 VOLVO DBL...
HITACHI ZAXIS 250LC-6N EXCAVATOR (A51246)
HITACHI ZAXIS...
(3) UNUSED MR HEATER PORTABLE PROPANE AIR HEATER (A51247)
(3) UNUSED MR...
2011 WABASH 53x102 DRY VAN (A53426)
2011 WABASH 53x102...
2012 Bomag BC572 Refuse Compactor (A51691)
2012 Bomag BC572...
ECHO SRM-225 GAS WEED EATER (A51248)
ECHO SRM-225 GAS...
