Woods Brush Hog Gear Oil
   / Woods Brush Hog Gear Oil #1
Buckchaser
Bradford PA
Massey F 1734
Could anyone tell me what type gear oil is best for an older Woods Brush Hog and also for a King Kutter tiller ?
   / Woods Brush Hog Gear Oil #2
I use 75-140 synthetic in everything
But I do live in ca where it's hot then hotter
   / Woods Brush Hog Gear Oil #3
The Owners Manual for my 1976 Woods M5-4 Rotary Cutter says to use #90 transmission oil (also called gear oil).
   / Woods Brush Hog Gear Oil #4
There are better gear oils now, plus they have a wider viscosity range. 75w-90 would be a good choice. It flows at low temperature a lot like 20w motor oil, but has the shear resistance of a 90wt gear oil.
rScotty
   / Woods Brush Hog Gear Oil #5
75-140 is gear oil just use the synthetic pricey but worth the money
They sell in 80 90 weight also
But use what you are comfortable with
   / Woods Brush Hog Gear Oil #6
older mower seals might be at risk with full synthetic having used dyno all it's life, but that may well be a myth for modern synthetics
but agree, 75/180 syn would cover all the needs, regards
LOT IDENTIFIER 17 (A53084)
LOT IDENTIFIER 17...
(APPROX 18) 2" X 6" X 68" THICK TUBING (A51247)
(APPROX 18) 2" X...
FRONTIER FAV20 LOT IDENTIFIER 42 (A53084)
FRONTIER FAV20 LOT...
TORO Z MASTER 2000 ZERO TURN MOWER (A51247)
TORO Z MASTER 2000...
2014 Vermeer SC802 Towable Stump Cutter (A51691)
2014 Vermeer SC802...
2013 FREIGHTLINER BUSINESS CLASS M2 VACUUM TRUCK (A51406)
2013 FREIGHTLINER...
