Woods Brush Hog Gear Oil
   / Woods Brush Hog Gear Oil #1
Buckchaser
Bradford PA
Massey F 1734
Can anyone let me know which gear oil is best for an older Woods Brush Hog and also for a rear tine King Kutter tiller ? Thanks for your help.
   / Woods Brush Hog Gear Oil #3
The manual for my 22 year old Woods BrushBull 60 calls for 80 or 90 wt, GL 4 or GL 5 gear oil in the gearbox.
   / Woods Brush Hog Gear Oil #5
OK. Thanks All. I have 80-90 wt. I will use that.
Should make sure it's also a GL4 or GL5. Those grades can handle higher pressures and resist shear better than lower grades.
   / Woods Brush Hog Gear Oil #6
   / Woods Brush Hog Gear Oil #8
I use "Corn Head" or grease 0 it is all that I use in all my gear boxes old or new. An since most gear boxes do not have a drain so you can change/flush the lubricant for the most part it is a fill and forget deal unless there is a major failure.
   / Woods Brush Hog Gear Oil #9
Don't know about no corn picker cotton heads but down here we use full synthetic 75-145. Comes in a new limp squeeze tube now. :rolleyes:
   / Woods Brush Hog Gear Oil #10
80-90 GL5 is what I use.
Ain’t never seen any cotton picker grease in a store around here but no one grows cotton around here either.
40' CONTAINER (A51248)
JOHN DEERE 1705/6700 LOT NUMBER 20 (A53084)
JOHN DEERE...
2015 INTERNATIONAL 28 PASSENGER HANDICAP ACCESSIBLE SHUTTLE BUS (A52577)
2015 INTERNATIONAL...
2012 Trail-Eze TE801 48ft 50 Ton Slide-Axle T/A Tilt Trailer (A51692)
2012 Trail-Eze...
Ford 345C Tractor with Loader (A51573)
Ford 345C Tractor...
2020 Kinze 3505 High Speed 6/11 Planter (A53472)
2020 Kinze 3505...
