Woods Brush Hog Gear Oil
   / Woods Brush Hog Gear Oil #1
Buckchaser
Bradford PA
Massey F 1734
Can anyone let me know which gear oil is best for an older Woods Brush Hog and also for a rear tine King Kutter tiller ? Thanks for your help.
   / Woods Brush Hog Gear Oil #3
The manual for my 22 year old Woods BrushBull 60 calls for 80 or 90 wt, GL 4 or GL 5 gear oil in the gearbox.
   / Woods Brush Hog Gear Oil #5
OK. Thanks All. I have 80-90 wt. I will use that.
Should make sure it's also a GL4 or GL5. Those grades can handle higher pressures and resist shear better than lower grades.
   / Woods Brush Hog Gear Oil #8
I use "Corn Head" or grease 0 it is all that I use in all my gear boxes old or new. An since most gear boxes do not have a drain so you can change/flush the lubricant for the most part it is a fill and forget deal unless there is a major failure.
   / Woods Brush Hog Gear Oil #9
Don't know about no corn picker cotton heads but down here we use full synthetic 75-145. Comes in a new limp squeeze tube now. :rolleyes:
   / Woods Brush Hog Gear Oil #10
80-90 GL5 is what I use.
Ain’t never seen any cotton picker grease in a store around here but no one grows cotton around here either.
2004 IC Corporation 3000IC School Bus (A51692)
2004 IC...
2010 JOHN DEERE 4730 LOT IDENTIFIER 239 (A53084)
2010 JOHN DEERE...
Bobcat 14" Hydraulic Asphalt Plainer (A52384)
Bobcat 14"...
2022 MGT CM11CUFT S/A Towable Concrete Mixer (A51691)
2022 MGT CM11CUFT...
JOHN DEERE 408R (A53084)
JOHN DEERE 408R...
UNIVERSAL WOLVERINE PFF2-13-45W QUICK ATTACH MAST (A51248)
UNIVERSAL...
