Woods BH80-X
/ Woods BH80-X #21
Yea, the seat valve. That should work, Thanks BigDogs.
The only other thing I have to do is disconnect the 3 pt side brace arms.
Mine is for sale too if I could get a decent price for it.
Larry
/ Woods BH80-X #22
I tried closing off the 3ph valve to keep it from moving up into the bh frame. What I found was that it keeps it from dropping, but not from raising. In fact, the 3ph was raising up "by itself" with the valve closed even though I never moved the lift lever. I'm not sure why it does this.
/ Woods BH80-X #23
</font><font color="blue" class="small">( I tried closing off the 3ph valve to keep it from moving up into the bh frame. What I found was that it keeps it from dropping, but not from raising. In fact, the 3ph was raising up "by itself" with the valve closed even though I never moved the lift lever. I'm not sure why it does this.
)</font>
That's just how that valve is supposed to operate. I think the suggestion was to raise the arms and then lock down the valve to keep the arms from dropping.
Why yours is raising without the lever in the up position is a wonder.
On my CK20, I can raise the arms and then let them rest on the backhoe frame, hitch lever in the low position, because I have on Pat's easy hitches on the ends of the arms which allows them to sit right on the frame.
John
/ Woods BH80-X #24
Hey are your arms still raising by themselves?
I have noticed that when I run the machine I have a tendency to bump the lever.
/ Woods BH80-X #25
I'm positive I haven't bumped the lever. It hasn't happened since I left the speed valve open.
