Woods BB72 blades "stuck"
/ Woods BB72 blades "stuck" #1
Flying MXZ
Bronze Member
Catskills, NY
Massey 1635
There is a Woods Brushbull 72 for sale locally. It looks in pretty good shape, has been used but not too bad. Only problem I see is that the blades are "stuck" to their housing. Is this a common problem, easy fix? He had sprayed wd40 or similar on it when I looked at it last week. It was still for sale earlier today. He is asking $600, sound decent depending on the blade situation?
/ Woods BB72 blades "stuck" #2
Do you mean the blades won't pivot on the mounting bolts? I've had that problem when my cutter sat up for awhile; in my case they broke free as soon as i started cutting. Worst case scenario you can undo the bolts (you WILL need an impact wrench), drop the blades and then reinstall them.
That's a very good price if the mower doesn't have any other issues.
Thanks, I looked at it again today and the blades broke loose with a little effort by hand so I think it is fine.
/ Woods BB72 blades "stuck" #4
As mentioned, they will probably free up the first time you run it. I had the same thing happen and they freed up by running. If you have to remove them use never sieze when reinstalling.
Oops, just saw you posted you got them freed up while I was typing this.
