Backhoe Woods backhoe
/ Woods backhoe #1
JRS
Tucson, Arizona
Ford 3550 Industrial / 1937 John Deere Model B/ 4310 John Deere
Does anyone know if a Woods T 308 or T 30 ( don't know which model number is correct) three point backhoe will work on a 4310. I have the power beyond installed on the tractor. I have not seen the backhoe but the individual who is selling it for the owner says it's about 2/3 the size of a large unit.
Thanks in advance, John
/ Woods backhoe #2
<font color="blue"> Does anyone know if a Woods T 308 or T 30 ( don't know which model number is correct) three point backhoe will work on a 4310 </font>
I can't imagine that a 3 point mount us ANYWHERE satisfactory compared to the Deere mount. The mounting is no little thing, even a little hoe can put tremendous stress on the tractor, If your machine is in warranty, I'd be sure and verify compatibility with the Deere dealer. Even out of warranty, it would be worth finding out.
/ Woods backhoe #3
A 3PH backhoe is the fastest way I can think of to break your tractor into two pieces. Call your JD dealer and ask them for their input before you get one.
/ Woods backhoe #4
If 3pt. hoes are so dangerous to the tractor, why does Deere put them on their 4000 TEN series? /forums/images/graemlins/confused.gif
/ Woods backhoe #5
The three point hoes are fine for utility tractors, but not compacts. Utilities are built heavy enough that they can handle the stress.
/ Woods backhoe #6
<font color="green"> If 3pt. hoes are so dangerous to the tractor, why does Deere put them on their 4000 TEN series? </font>
They don't. The first step in installing the hoe is removing the 3 point arm assembly. The hoe mounts to a special frame on the back of the tractor, its really heavy and couples the two closely together. The 46 is a subframe model and also doesn't mount to the 3ph.
2023 John Deere XUV 825M S4 (A60462)
2023 John Deere...
2025 Kivel Fork and Frame Mini Skid Steer Attachment (A61572)
2025 Kivel Fork...
2012 John Deere 328D Compact Wheel Loader Skid Steer (A61572)
2012 John Deere...
John Deere 5045E for sale
John Deere 5045E...
4004SFL (A59228)
4004SFL (A59228)
2016 Ford F-150 Crew Cab Pickup Truck (A59228)
2016 Ford F-150...
