Woods 1009 FEL QA bucket question
   / Woods 1009 FEL QA bucket question #1
DavidVT
NorthEastern VT
Kubota 3430
To any Woods experts:
I have a new Woods 1009 FEL with a skid steer style QA bucket.
I notice that the leading edge of the bucket has a row of empty holes. Is this for a cutting edge and/or perhaps toothbar? Does one source these from woods or aftermarket vendors?
I don't see this exact loader and QA setup on the Woods site so am having trouble determining what I can add to this 66" bucket.
Hopefully I can figure this out before I bend the bucket during the 'tuition phase' of ownership...
Thanks
   / Woods 1009 FEL QA bucket question #2
Dave most buckets are drilled for a reversible cutting edge that also strengthens the leading edge of the bucket when it's in place.
I use mine in the winter and replace it with the tooth-bar for warm weather duties. I actually think a tooth-bar has more use than a reversible cutting edge but that's just my personal opinion.
Thanks Mike,
I was looking at sites regarding a tooth bar and noticed that one (Markham I believe) mentioned they were designed for welded cutting edges.
A Neubie question here...
Will my bucket (with these holes), be appropriate for Markham or should I seek a toothbar from Woods?
Thanks..
   / Woods 1009 FEL QA bucket question #4
Dave I think what they are trying to tell you is that that particular tooth-bar will fit over a cutting edge.
Mine will not so I need to alternate one or the other.
All the tooth-bars that I have ever seen mount with 2 bolts. One on each side of the bucket drilled through the end plates (vertical section) of the bucket.
I have never seen any that bolted to the same holes in the leading edge as the cutting edge. Might be made I just don't know.......
Thanks Mike,
I asked a friend to come by and he identified the welded cutting edge and explained the holes in the side of the bucket were for the toothbar.
Thanks
David
2015 Goose Neck Cattle Trailer (A53317)
2015 Goose Neck...
John Deere Gator (A53317)
John Deere Gator...
Case Axial-Flow Combine Wheels NO RESERVE (A56438)
Case Axial-Flow...
2013 CATERPILLAR 950K WHEEL LOADER (A60429)
2013 CATERPILLAR...
2014 Cadillac ATS Sedan (A59231)
2014 Cadillac ATS...
2018 Chevrolet Impala Premier Sedan (A59231)
2018 Chevrolet...
