Wood working clamps
   / Wood working clamps #31
What's your shipping costs for this Rt Angle ? Although it is very simple to make, he used 2-3 jigs and a plunge router [which I have only learned of this tools name in the last 2 weeks] along w various other start-stop measures...nice !
that's not my jig. the corner clamps I made for myself is just a triangle of plywood with some 1x2 attached to the 90 degree sides. no fancy holes to cut. The the one corner perfectly square, glue/screw on some 1x2 wood. leave a notch in the corner for glue squeeze out so it does get stuck to whatever you're making.
not nearly as pretty but works great.
   / Wood working clamps #32
I hear you on a 5-6ft pipe/clamps for a 2 ft need is cumbersome. What do you think about the concept of buying X amt of 2ft and 3ft 3/4" black threaded pipes, then a dozen 3/4" female couplers where it would take 1 min to join 2 diff size pipes giving you options on 4ft, 5ft or 6ft, and of course the orig 2ft & 3ft pipes as well ? of course you could go up to 7-10ft as well.
As far as pipe clamps, would you say the Pony Jorgersens are the best? Thanks again
I don’t like a coupling in the pipe. It makes it hard to keep your boards level. But in theory it would work. I bought Bessey pipe clamps because they have feet on them to keep them upright. But they’re also wider so it might be better to have some of both.
   / Wood working clamps #33
I also use Titebond glue for most wood furniture projects. It sets in 2 hrs so clamps can be removed. Cures in 24 hrs. Water soluble for cleanup with wet paper towel. Can use a scraper to remove any cured glue missed in cleanup before surfacing.
Ahh yes,clamps aren't much use without a dab of glue. My contribution to the subject is don't use your fingers to spread polyurethane glue. I once worked with a guy that knew everything about anything and was always eager to one up or top what other people said. To his credit,he was an accomplished woodworker. We were building desks and cabinets in an office when he showed me a bottle of glue that had just came on the market. I told him I had already tried some and liked it for some applications but I thought Titebond better suited for the project at hand. Not at all suprisinly he insisted we use his new discovery. When it was time for glue I produced "special" glue spreading gloves only available from some obscure outlet in Italy. He got a good laugh and told me i had wasted money then showed me how much better he could spread glue with his bare hands. The next day he had what looked like greenish-grey bruises all over his face,arms and hands.
   / Wood working clamps #34
Either pipe clamps or bar clamps are infinitely adjustable. A 5 foot long one will go all the way down to nothing. It’s kinda aggregating to use a long clamp for short clamp work though.
Pipe clamps work well but only buy the clamps intended for 3/4” pipe.
lenth cab be zero to infinity depending on the length of the pipe.
I have a stash of threaded pipe from 12” to 60” and a handful of couplings so if necessary can couple assorted lengths together to obtain a length suitable for the task at hand.
As a third hand when assembling large panels as in cabinet construction, I keep an inventory of 3 X 3” X 1/8 angle iron about 3” long and with spring clamps things stay in position for fastening.
B. John
Thanks Bud J.
4570, thanks again. Last question before I start to go out and buy the supplies.
You mentioned a coupling btw 2 pipes makes it hard to keep your boards level. Isn't there enough play in the ends of the clamps to offset the add'l OD of the coupling beyond the pipe? I have never used any type of pipe clamps before so I am only going on pics I have seen and videos.
   / Wood working clamps #38
Thanks Bud J.
You mentioned a coupling btw 2 pipes makes it hard to keep your boards level. Isn't there enough play in the ends of the clamps to offset the add'l OD of the coupling beyond the pipe? I have never used any type of pipe clamp before so I am only going on pics I have seen and videos.
Yes there is but then you’ll have to use a set of cauls to keep the glue up fist where I usually just use the clamp bar.
   / Wood working clamps #39
And get some innertubes to slice into long elastic strip clamps. Elastic clamping has one advantage that few other clamps have - they keep the glue joint tight as the wood expands and contracts. Most of the time that doesn't matter in woodworking. But with highly stressed and flexible joints - boats and archery - it's critical.
You can't have two many clamps.
rScotty
   / Wood working clamps #40
rScotty
There’s also tape. It works pretty good for light duty mitered cuts.
Mini Skid-Steer Hydraulic Side Shifting Forks (New/Unused) (A59225)
Mini Skid-Steer...
2007 Volvo VNL Tri-Axle Dump Truck (A56858)
2007 Volvo VNL...
2014 Ford Transit Connect Cargo Van (A54814)
2014 Ford Transit...
500 BBL FRAC TANK (A58216)
500 BBL FRAC TANK...
2016 Snorkel S4732 Scissor Lift (A57453)
2016 Snorkel S4732...
Giyi 59" Vibratory Roller (A57149)
Giyi 59" Vibratory...
