Just a couple more points as I have this stoves bigger brother (5700) If you still get that blow torch effect when you crack open the stove door, then it is not your draft. This should be a pretty strong, sustaining blow and not only at the beginning when you just crack the door open. A weak air flow here would pin point to a draft problem of some sort as described in previous posts. If your stove is a miniature version of the 5700 Quadrafire, then you should have 2 "air intake" tubes showing their orifice at the back of your stove. Make sure you place a vacuum cleaner over these tubes to suck up any ash that may have dropped inside as a result of cleaning your stove. (even if you have an ash pan, ash can get up into the tubes with logs acting with a bulldozer effect on the ash already in the stove pushing into the tubes. Thirdly and as far fetched as it may seem, the stove activates its draft with actuator rods for primary and secondary air intakes. Make sure the plates they weld to the ends of these rods which act as air dampers, are still welded onto the rods. If one did come off, it could be blocking an air inlet. Stove heat shield would have to be removed which is easy to do for viewing.
