Wood Stove problem
/ Wood Stove problem #11
when I clean our Vermont Casting after I wire brush it from the roof with poles I have to disconnect the pipe inside that attaches to the stove and remove all of the creosote by hand and vacuum. I always wear cloves and always make sure the stove is completely cool as the other poster mentioned.It also goes into a 6" pipe into the attic and out the roof,should have used a 8" as the 8 draft much better. At the time I was impatient did not want to special order and wait for the 8" will never make that mistake again.
Clearing the snow away seemed to help...a little anyway. I think I will still the rep tomorrow to see if they have any ideas.
/ Wood Stove problem #13
TRY opening a window near the stove ,just to see if it is an lack of air problem.Are the grates between the stove and ash pan blocked?Mine need to be shaken if the fire wont burn.Also dont let the ashes build up to the grates ,it will block air flow and warp your grates from lack of air and too hot of grates
ALAN
/ Wood Stove problem #15
ALAN
I was going to write the same thing. Cold chimney can also slow down air circulation, once the chimney gets up to temp it causes a better draft.
/ Wood Stove problem #16
If it worked good before and is now sluggish even with a window opened then it's most likely your wood. Easy to check, go source some known dry wood from a supermarket and if that burns well then you know what your problem is.
Your chimney does not need to be above your roof. It is supposed to meet the 10/2/3 rule which states that the top must be 2 feet above any part of the roof within 10 feet and a minimum of 3 feet above the roof penetration. The 2 foot accumulation of snow might render your installation out of compliance with the rule. Still though, it should be close enough to burn.
UPDATE: Spoke to the gent who I bought the stove from and who installed it and he ran me through some stuff to check. I had done most of them already. He said one thing that will cause the problems I'm having is a bunched up blanket above the burn tubes. Sure enough, mine has become out of shape. I trimmed it to match the size of the board it sits on and made sure it is pushed flush up against the back wall. It does seem to be burning better.
I have to wonder though, as highbeam suggests, if my wood is OK. I may have to try some supermarket wood as a test. The stuff I'm using is 3 year old Cherry that has been under cover. It is burning better and maybe it's my imagination but I think I've got a better burn in the past, but I used to have just powder ashes in the morning. Now I will have chunks.
At any rate, it does seem to be a bit better. Many thanks to all of you.
/ Wood Stove problem #18
I don't think this is your problem but in a very tight house trying to light a fire with the clothes dryer running can be "interesting."
The fire is trying to draw up a cold chimney...
But the dryer is taking air from the house and blowing it outside....
Later,
Dan
/ Wood Stove problem #19
Coach
As HighBeam suggested try good seasoned wood, if you are finding "chunks" then it isn't burning as it should.
Harvey
/ Wood Stove problem #20
Just a couple more points as I have this stoves bigger brother (5700) If you still get that blow torch effect when you crack open the stove door, then it is not your draft. This should be a pretty strong, sustaining blow and not only at the beginning when you just crack the door open. A weak air flow here would pin point to a draft problem of some sort as described in previous posts. If your stove is a miniature version of the 5700 Quadrafire, then you should have 2 "air intake" tubes showing their orifice at the back of your stove. Make sure you place a vacuum cleaner over these tubes to suck up any ash that may have dropped inside as a result of cleaning your stove. (even if you have an ash pan, ash can get up into the tubes with logs acting with a bulldozer effect on the ash already in the stove pushing into the tubes. Thirdly and as far fetched as it may seem, the stove activates its draft with actuator rods for primary and secondary air intakes. Make sure the plates they weld to the ends of these rods which act as air dampers, are still welded onto the rods. If one did come off, it could be blocking an air inlet. Stove heat shield would have to be removed which is easy to do for viewing.
2011 MACK CHU (PINNACLE) (A60736)
2011 MACK CHU...
Year: 2011 Make: Chevrolet Model: Express Vehicle Type: Van Mileage: 118,735 Plate: Body Type: 3 (A59230)
Year: 2011 Make...
1629 (A57192)
1629 (A57192)
Roll of 2-inch Vacuum Hose (A57454)
Roll of 2-inch...
2010 International 7400 Service Truck with Crane, VIN # 1HTWGAAR4AJ276527 (A61165)
2010 International...
ROSCO SPR-H CHIP SPREADER (A59823)
ROSCO SPR-H CHIP...
