Wood splitting with a B3200
   / Wood splitting with a B3200 #11
I use a Super Split with 2 second cycle time.
No way I could get by with a slow tractor mount splitter.
   / Wood splitting with a B3200 #12
Another reason for a 3pt splitter. One less engine to maintain... You'll hear both side of this argument all day long.. I burn 3 cords a year for my cape size house. The Powerhorse is great unit as I stated in my earlier post...... Good luck
   / Wood splitting with a B3200 #13
I didn't see cost listed on my smsll phone screen... But the cost of putting remotes is probably highr than a 3pt pto pump. less flexible but will have 3x the flow and a larger fluid volume.
   / Wood splitting with a B3200 #14
Do you have a 4 way on the super split? I can quarter logs < 4 seconds with my tractor mounted split fire. It took a minimum 3 splits with the speed pro kinetic i took back to quarter a log Because the push blocks are so small on the kinetics you can not double stack the halves. The other thing i did not like with the super split style was the propensity of the splitter to propel large pieces of gnarly wood back at the operator at high speed. It was fast though super split definitely makes the best kinetic splitter. It was also a pain to lift 24"- 30" pieces onto the table. Log lift on the split fire fixed that problem
Dave
   / Wood splitting with a B3200 #15
It would be nice if someone made a 3PH kinetic log splitter.
International 5088 2wd Cab Tractor (A52128)
International 5088...
1994 Chevy  2500 Dually Pick Up Truck (A50515)
1994 Chevy 2500...
Walking Floor Trailer (A50322)
Walking Floor...
2018 Kinze 3500 Planter (A52349)
2018 Kinze 3500...
2011 Ford Edge SEL SUV (A50324)
2011 Ford Edge SEL...
2-Row Peanut Inverter (Chain Drive, PTO, 3-Point Hitch) (A52128)
2-Row Peanut...
