Wood splitting with a B3200
   / Wood splitting with a B3200 #11
I use a Super Split with 2 second cycle time.
No way I could get by with a slow tractor mount splitter.
   / Wood splitting with a B3200 #12
Another reason for a 3pt splitter. One less engine to maintain... You'll hear both side of this argument all day long.. I burn 3 cords a year for my cape size house. The Powerhorse is great unit as I stated in my earlier post...... Good luck
   / Wood splitting with a B3200 #13
I didn't see cost listed on my smsll phone screen... But the cost of putting remotes is probably highr than a 3pt pto pump. less flexible but will have 3x the flow and a larger fluid volume.
   / Wood splitting with a B3200 #14
Do you have a 4 way on the super split? I can quarter logs < 4 seconds with my tractor mounted split fire. It took a minimum 3 splits with the speed pro kinetic i took back to quarter a log Because the push blocks are so small on the kinetics you can not double stack the halves. The other thing i did not like with the super split style was the propensity of the splitter to propel large pieces of gnarly wood back at the operator at high speed. It was fast though super split definitely makes the best kinetic splitter. It was also a pain to lift 24"- 30" pieces onto the table. Log lift on the split fire fixed that problem
Dave
   / Wood splitting with a B3200 #15
It would be nice if someone made a 3PH kinetic log splitter.
2015 Chevrolet Silverado 1500 4x4 Crew Cab Pickup Truck (A50323)
2015 Chevrolet...
2018 Land Rover Range Rover Supercharged 4WD SUV (A50324)
2018 Land Rover...
FORD COBRA REPLICA RACING CAR (A51222)
FORD COBRA REPLICA...
2019 FREIGHTLINER CASCADIA DAY CAB (A51222)
2019 FREIGHTLINER...
2017 Ford E450 Super Duty 20 Passenger Bus (A47384)
2017 Ford E450...
2014 INTERNATIONAL 7400 SBA 42 LUBE TRUCK (A51406)
2014 INTERNATIONAL...
